Intel® MPI Library
2285 Discussions
Passing macro definitions (strings) to mpicc/mpicxx seems broken
gryghash
UPDATE: I have been hasty. I do not have a fix. Leaving the mpicc and mpicxx scripts alone but using mpiicc and mpiicpc seems to work. Apologies for going off half-cocked.
I just had a report from a user about passing macro definitions via the -D commandline argument to mpicxx. The test source file included at the end of this message. I can confirm his findings.
The product being used is Intel Cluster Studio XE 2012: icc (ICC) 12.1.0 20110811
The compile line is:
mpicxx -DTESTMACRO1="[BACKSLASH]"ABC[BACKSLASH]"" -DTESTMACRO2="[BACKSLASH]"CDE [BACKSLASH]"" -DTESTMACRO3="[BACKSLASH]"FG HI[BACKSLASH]"" -c macrotest.cpp
[NB - the text input here strips backslashes, so I've used [BACKSLASH] to indicate the single character backslash ]
which gives this error:
icpc: error #10236: File not found: '"'
icpc: error #10236: File not found: 'HI"'
macrotest.cpp(5): error: missing closing quote
"Macro 2 " TESTMACRO2 "\\n"
macrotest.cpp(6): error: missing closing quote
"Macro 3 " TESTMACRO3
compilation aborted for macrotest.cpp (code 2)
make: *** [macrotest.o] Error 1
The exact same source file and commandline arguments work with other MPI implementations including openmpi-1.5.3-3 on RHEL6. The problem seems to stem from the way the mpicc and mpicxx scripts handle the arguments.
Thanks for your attention,
Dave Chin
============= macrotest.cpp =====================
const char* macrotest() {
return
"Macro 1 " TESTMACRO1 "\\n"
James_T_Intel
Hi Dave,
Thank you for the defect report. I have submitted this internally. As far as the fix you had posted, I will remove that from the defect report when it is available.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel Cluster Tools
gryghash
Thanks, James. Much obliged.
