- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
When I ran with IMPI benchmark, it always got an obvious performance drop when buffer size>128MB with OFI, is this reasonable or there is some configuration? Thanks
mpirun -genv I_MPI_STATS=ipm -genv I_MPI_FABRICS=tmi -n 2 -ppn 1 -f hostfile IMB-MPI1 -msglog 20:29 -iter 20000,1000 uniband -time 1000000 -mem 2
# Benchmarking Uniband
# #processes = 2
#bytes #repetitions Mbytes/sec Msg/sec
0 20000 0.00 607266
1048576 1000 8356.72 7970
2097152 500 8847.71 4219
4194304 250 9295.13 2216
8388608 125 9205.23 1097
16777216 62 9498.35 566
33554432 31 9577.55 285
67108864 15 9564.31 143
134217728 7 9523.83 71
268435456 3 2700.73 10 <-----------performance dropped much
536870912 1 3514.32 7
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Zhoulong,
It is expected that you see drop starting after 128 MB. It is related with memory registration mechanism on OPA driver level. You need to adjust OPA driver parameters for such large messages. OPA driver parameters can be found at /sys/module/hfi1/parameters.
Try the following:
- set max_mtu=10240
- increase cache_size from 256 to higher value (for example 512 or 1024)
- decrease num_user_contexts (for example 16)
- use huge pages in your application
More information about OPA performance tuning can be found here:
https://www.intel.com/content/dam/support/us/en/documents/network-and-i-o/fabric-products/Intel_OP_Performance_Tuning_UG_H93143_v10_0.pdf
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
