Intel® MPI Library
2274 Discussions
Problem in submitting job (MPI related) through HPC job manager
JSRhee
Hi
I'm using fotran code and In my server we use both mpi from oneAPI and MSMPI
(Through Windows OS)
Actually, I have no problem in executing my mpi fotran code through oneAPI command prompt
(ex) mpiexec  -np 1 program)
But in the cmd (original Command Prompt),  'mpiexec -np 1 program' causes an error "impi.dll is missing"
It seems that library is not linked in the CMD.
I found out that if i execute vars.bat (in the mpi/latest/env directory), cmd is changed as "Intel(R) MPI Library build Environment for Intel(R) 64 applications" Then "mpiexec" works perfectly.
It seems that mpi commands are linked to "MSMPI" in the cmd.  And i guess it's the problem.
For this reason, when i submit jobs to clusters through command "mpiexec -np 1 program" (by HPC job manager) ,  same problem occur.
programs without using MPI have no issue.
How can i change the default MPI environment as "oneAPI" not "MSMPI"
or any other solutions ..?
Thank you in advance
TobiasK
@JSRhee
please make sure that the PATH variable is correctly set up.
