Intel® MPI Library
Re: Intel oneAPI with Podman
ugiwgh
Sorry, I cannot reply any comments. So I post a new one.
I use macOS Big Sur, version 11.1(20C69), and Google Chrome version 100.0.4896.75. I change many ways, still cannot reply an comments. Such as, safari(on macOS), Microsoft Edge.
$ mpirun --version
Intel(R) MPI Library for Linux* OS, Version 2021.5 Build 20211102 (id: 9279b7d62)
Copyright 2003-2021, Intel Corporation.
$ podman --version
podman version 4.0.2
$ podman version
Client: Podman Engine
Version: 4.0.2
API Version: 4.0.2
Go Version: go1.16.13
Git Commit: c99f9f1b6960b98158b7f5fc4e6b5ac1a10b3542
Built: Wed Mar 23 18:33:41 2022
OS/Arch: linux/amd64
$ cat /etc/centos-release
CentOS Linux release 7.9.2009 (Core)
$ uname -a
Linux ln131.para.bscc 3.10.0-1160.25.1.el7.x86_64 #1 SMP Wed Apr 28 21:49:45 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
The code is intel/oneapi/mpi/2021.5.1/test/test.c.
#include "mpi.h"
#include <stdio.h>
#include <string.h>
int main(int argc, char *argv[])
    int i, rank, size, namelen;
    char name[MPI_MAX_PROCESSOR_NAME];
    MPI_Status stat;
    MPI_Init(&argc, &argv);
    MPI_Comm_size(MPI_COMM_WORLD, &size);
    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
    MPI_Get_processor_name(name, &namelen);
    if (rank == 0) {
        printf("Hello world: rank %d of %d running on %s\n", rank, size, name);
        for (i = 1; i < size; i++) {
            MPI_Recv(&rank, 1, MPI_INT, i, 1, MPI_COMM_WORLD, &stat);
            MPI_Recv(&size, 1, MPI_INT, i, 1, MPI_COMM_WORLD, &stat);
            MPI_Recv(&namelen, 1, MPI_INT, i, 1, MPI_COMM_WORLD, &stat);
            MPI_Recv(name, namelen + 1, MPI_CHAR, i, 1, MPI_COMM_WORLD, &stat);
    } else {
        MPI_Send(&rank, 1, MPI_INT, 0, 1, MPI_COMM_WORLD);
        MPI_Send(&size, 1, MPI_INT, 0, 1, MPI_COMM_WORLD);
        MPI_Send(&namelen, 1, MPI_INT, 0, 1, MPI_COMM_WORLD);
        MPI_Send(name, namelen + 1, MPI_CHAR, 0, 1, MPI_COMM_WORLD);
    MPI_Finalize();
    return (0);
I use the following command. The envfile is mpi enviroment in container.
mpirun -np 1 podman run --env-host --env-file envfile --userns=keep-id --network=host --pid=host --ipc=host -w /exports -v .:/exports:z dptech/vasp:5.4.4 /exports/mpitest
The following is envfile.
MKLROOT=/opt/intel/oneapi/mkl/2022.0.2
MANPATH=/opt/intel/oneapi/mpi/2021.5.1/man:/opt/intel/oneapi/debugger/2021.5.0/documentation/man:/opt/intel/oneapi/compiler/2022.0.2/documentation/en/man/common::
LIBRARY_PATH=/opt/intel/oneapi/tbb/2021.5.1/env/../lib/intel64/gcc4.8:/opt/intel/oneapi/mpi/2021.5.1//libfabric/lib:/opt/intel/oneapi/mpi/2021.5.1//lib/release:/opt/intel/oneapi/mpi/2021.5.1//lib:/opt/intel/oneapi/mkl/2022.0.2/lib/intel64:/opt/intel/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin:/opt/intel/oneapi/compiler/2022.0.2/linux/lib
OCL_ICD_FILENAMES=libintelocl_emu.so:libalteracl.so:/opt/intel/oneapi/compiler/2022.0.2/linux/lib/x64/libintelocl.so
LD_LIBRARY_PATH=/home/rsync/.local/container/lib64:/home/rsync/.local/container/lib:/opt/intel/oneapi/tbb/2021.5.1/env/../lib/intel64/gcc4.8:/opt/intel/oneapi/mpi/2021.5.1//libfabric/lib:/opt/intel/oneapi/mpi/2021.5.1//lib/release:/opt/intel/oneapi/mpi/2021.5.1//lib:/opt/intel/oneapi/mkl/2022.0.2/lib/intel64:/opt/intel/oneapi/debugger/2021.5.0/gdb/intel64/lib:/opt/intel/oneapi/debugger/2021.5.0/libipt/intel64/lib:/opt/intel/oneapi/debugger/2021.5.0/dep/lib:/opt/intel/oneapi/compiler/2022.0.2/linux/lib:/opt/intel/oneapi/compiler/2022.0.2/linux/lib/x64:/opt/intel/oneapi/compiler/2022.0.2/linux/lib/oclfpga/host/linux64/lib:/opt/intel/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin
FPGA_VARS_DIR=/opt/intel/oneapi/compiler/2022.0.2/linux/lib/oclfpga
FI_PROVIDER_PATH=/opt/intel/oneapi/mpi/2021.5.1//libfabric/lib/prov:/usr/lib64/libfabric
CMPLR_ROOT=/opt/intel/oneapi/compiler/2022.0.2
CPATH=/opt/intel/oneapi/tbb/2021.5.1/env/../include:/opt/intel/oneapi/mpi/2021.5.1//include:/opt/intel/oneapi/mkl/2022.0.2/include:/opt/intel/oneapi/dev-utilities/2021.5.2/include
INTELFPGAOCLSDKROOT=/opt/intel/oneapi/compiler/2022.0.2/linux/lib/oclfpga
NLSPATH=/opt/intel/oneapi/mkl/2022.0.2/lib/intel64/locale/%l_%t/%N:/opt/intel/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin/locale/%l_%t/%N
PATH=/home/rsync/.local/container/bin:/home/rsync/.local/container/sbin:/opt/intel/oneapi/mpi/2021.5.1//libfabric/bin:/opt/intel/oneapi/mpi/2021.5.1//bin:/opt/intel/oneapi/mkl/2022.0.2/bin/intel64:/opt/intel/oneapi/dev-utilities/2021.5.2/bin:/opt/intel/oneapi/debugger/2021.5.0/gdb/intel64/bin:/opt/intel/oneapi/compiler/2022.0.2/linux/lib/oclfpga/bin:/opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64:/opt/intel/oneapi/compiler/2022.0.2/linux/bin:/home/rsync/.local/bin:/public1/clurm/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/ibutils/bin:/home/rsync/.local/bin:/home/rsync/bin:/opt/vasp.5.4.4/bin
TBBROOT=/opt/intel/oneapi/tbb/2021.5.1/env/..
INTEL_PYTHONHOME=/opt/intel/oneapi/debugger/2021.5.0/dep
CLASSPATH=/opt/intel/oneapi/mpi/2021.5.1//lib/mpi.jar
PKG_CONFIG_PATH=/opt/intel/oneapi/tbb/2021.5.1/env/../lib/pkgconfig:/opt/intel/oneapi/mpi/2021.5.1/lib/pkgconfig:/opt/intel/oneapi/mkl/2022.0.2/lib/pkgconfig:/opt/intel/oneapi/compiler/2022.0.2/lib/pkgconfig
GDB_INFO=/opt/intel/oneapi/debugger/2021.5.0/documentation/info/
INFOPATH=/opt/intel/oneapi/debugger/2021.5.0/gdb/intel64/lib
CMAKE_PREFIX_PATH=/opt/intel/oneapi/tbb/2021.5.1/env/..:/opt/intel/oneapi/compiler/2022.0.2/linux/IntelDPCPP
ONEAPI_ROOT=/opt/intel/oneapi
I_MPI_ROOT=/opt/intel/oneapi/mpi/2021.5.1
_=/opt/intel/oneapi/mpi/2021.5.1/bin/mpiexec.hydra
HemanthCH_Intel
Thanks for posting in Intel communities.
We tried to run the mpi program using podman, but we are facing the issue as permission denied from the docker registry as shown below screenshot.
Is it a private registry? If yes, is it possible to give access to the registry?
Thanks & Regards,
Hemanth
HemanthCH_Intel
As you are facing issues to respond to the existing post in the Intel communities. So, we have contacted you privately, please check your inbox and respond back to us.
Thanks & Regards,
Hemanth.
HemanthCH_Intel
As we are communicating internally through emails, Since this is a duplicate thread of https://community.intel.com/t5/Intel-oneAPI-HPC-Toolkit/Re-Intel-oneAPI-with-Podman/m-p/1394023#M9611, we will no longer monitor this thread. We will continue addressing this issue in the other thread
Thanks & Regards,
Hemanth
