Intel® MPI Library
Intel oneAPI with Podman
ugiwgh
I have ran Intel MPI with Podman. There is something wrong.
$ mpirun -np 1 podman run --env-host --env-file envfile --userns=keep-id --network=host --pid=host --ipc=host -w /exports -v .:/exports:z dptech/vasp:5.4.4 /exports/mpitest
[cli_0]: write_line error; fd=9 buf=:cmd=init pmi_version=1 pmi_subversion=1
system msg for write_line failure : Bad file descriptor
[cli_0]: Unable to write to PMI_fd
[cli_0]: write_line error; fd=9 buf=:cmd=get_appnum
Abort(1090575) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(143):
MPID_Init(1221)......:
MPIR_pmi_init(130)...: PMI_Get_appnum returned -1
[cli_0]: write_line error; fd=9 buf=:cmd=abort exitcode=1090575
Attempting to use an MPI routine before initializing MPICH
^C[[email protected]] Sending Ctrl-C to processes as requested
[[email protected]] Press Ctrl-C again to force abort
^C
HemanthCH_Intel
Could you please provide us with the below details to investigate more on your issue?
1)Operating system details.
2)Intel MPI version.
3)Podman version.
4)Sample reproducer code and steps to reproduce your issue at our end.
Thanks & Regards,
Hemanth
HemanthCH_Intel
As you are facing issues to respond to the existing post in the Intel communities. So, we have contacted you privately, please check your inbox and respond back to us.
Thanks & Regards,
Hemanth.
HemanthCH_Intel
As we are communicating internally through emails, Since this is a duplicate thread of https://community.intel.com/t5/Intel-oneAPI-HPC-Toolkit/Re-Intel-oneAPI-with-Podman/m-p/1394023#M9611, we will no longer monitor this thread. We will continue addressing this issue in the other thread
Thanks & Regards,
Hemanth
