Intel® MPI Library
2275 Discussions
Segmentation fault on MPI, runs properly on OpenMP
bellman
I am trying to run a program on a computer cluster. The structure of the program is the following:
[fortran]PROGRAM something
CALL subroutine1(...)
END PROGRAM
SUBROUTINE subroutine1(...)
DO i=1,n
CALL subroutine2(...)
ENDDO
END SUBROUTINE
SUBROUTINE subroutine2(...)
CALL subroutine3(...)
CALL subroutine4(...)
END SUBROUTINE[/fortran]
The idea is to parallelize the loop that calls subroutine2. Main program basically only makes the call to subroutine1 and only its arguments are declared. I use two alternatives. On the one hand, I write OpenMP clauses arround the loop. On the other hand, I add an IF conditional branch arround the call and I use MPI to share the results.
In the OpenMP case, I add CALL KMP_SET_STACKSIZE(402653184) at the beginning of the main program and I can run it with 8 threads on an 8 core machine. When I run it (on the same 8 core machine) with MPI (either using 8 or 1 processors) it crashes just when makes the call to subroutine3 with a segmentation fault (signal 11) error. If I comment subroutine4, then it doesn't crash (notice that it crashed just when calling subroutine3 and it works when commenting subroutine4).
I compile with mpif90 using MPICH2 libraries and the following flags: -O3 -fpscomp logicals -openmp -threads -m64 -xS. The machine has EM64T architecture and I use a Debian Linux distribution. I set ulimit -s hard before running the program.
Any ideas on what is going on? Has it something to do with stack size?
Thanks in advance
bellman
Let me try to add some information in case it helps. The main purpose of the main program is to call subroutine1. Subroutine1 is the only one that makes calls to MPI/OpenMP functions. This subroutine is a Quasi-Newton minimization that I am probably allowed to share... so here it is its code:
[fortran]module Quasi_Newton
implicit none
private
public :: subroutine1
contains
subroutine subroutine1(p,nop,np,move,maxiter,stopcr)
use themodule
use omp_lib
implicit none
include 'mpif.h'
integer, intent(in) :: nop,np,move(nop),maxiter !Number of parameters, number of parameters to be moved, list of the parameters to be moved and max iterations
real(8), intent(inout) :: p(nop) !Parameter vector
real(8), intent(in) :: stopcr !Stopping criterion
integer :: iter, ipar, jpar, impar, jmpar, iproc !Counters
real(8) :: df(np), prevdf(np), ddf(np,np), tempdir(np,1), dir(nop) !Gradient, Gradient at previous iteration, Hessian, temporary allocation of direction vector and direction vector
real(8) :: y(np,1), identity(np,np), outer(np,np) !Gradient at xn1-gradient at xn, identity and outer matrix used to update the hessian
real(8) :: an, an1, adf, addf !Factor that multiplies the direction of movement, updated factor, first and second differentials with respect to an
real(8) :: func0,func1,func2,func3,func4,func5 !Function evaluations
real(8) :: p0(nop),p1(nop),p2(nop),p3(nop),p4(nop),p5(nop) !Vectors of parameters to be evaluated
real(8) :: xn(nop), xn1(nop) !Current and updated guesses of parameters
real(8), parameter :: eps=0.0002, c1=0.0001, c2=0.9 !Epsilon for the differentials and c1 and c2 parameters of the Wolfe conditions
logical :: matrix_ill !Logical matrix used in the inverse to detect wrong situations
real :: currtime !Variable to store the time used
!******* variables related mpi *******
integer :: ierror !return error message from mpi subroutines
integer :: id !identification number of each processor
integer :: nproc !total number of processors
integer:: tag !used for tag of send/recv operations
integer,dimension(mpi_status_size):: mpi_status !used to store status of mpi_recv
!******* initialization *******
!initialization of mpi environment
call mpi_init(ierror)
!obtain id for each node
call mpi_comm_rank(mpi_comm_world, id, ierror)
!returns the number of nodes
call mpi_comm_size(mpi_comm_world, nproc, ierror)
if (id==0) write (3,1000)
if (id==0) print 1100
!! FIRST ITERATION: CALCULATE JACOBIAN AT THE INITIAL GUESS OF PARAMETERS AND GUESS THE HESSIAN EQUAL I
xn=p
!! Compute the gradient
if (id==0) print 2100
impar=1
! !$omp parallel do num_threads(1) default(none) private(p1,p2,func1,func2,impar,currtime,ipar) shared(xn,df,nop,algorithm,globaltime,move)
do ipar=1,nop
if (move(ipar)==0) cycle
if ((sum(move(1:ipar))>=id*floor(1.*np/nproc)+1+id*(np-nproc*floor(1.*np/nproc)>=id)+&
(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc)(sum(move(1:ipar))<=(id+1)*floor(1.*np/nproc)+(id+1)*(np-nproc*floor(1.*np/nproc)>=id+1)&
+(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc)p1=xn
p2=xn
p1(ipar)=xn(ipar)+eps
call subroutine2(p1,func1,1)
currtime=secnds(globaltime)
print 2110, ipar, floor(currtime/3600) ,floor((currtime-floor(currtime/3600)*3600)/60),currtime-floor(currtime/60)*60, func1
p2(ipar)=xn(ipar)-eps
call subroutine2(p2,func2,1)
print 2111, ipar, floor(currtime/3600) ,floor((currtime-floor(currtime/3600)*3600)/60),currtime-floor(currtime/60)*60, func2
impar=sum(move(1:ipar))
df(impar)=(func1-func2)/(2*eps)
endif
enddo
! !$omp end parallel do
call mpi_barrier(mpi_comm_world,ierror)
if (id==0) then
do iproc=1,nproc-1
tag=iproc+100
call mpi_recv(df(iproc*floor(1.*np/nproc)+1+iproc*(np-nproc*floor(1.*np/nproc)>=iproc)+&
(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc)min((iproc+1)*floor(1.*np/nproc)+(iproc+1)*(np-nproc*floor(1.*np/nproc)>=iproc+1)&
+(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc),np-iproc*floor(1.*np/nproc)+1+iproc*(np-nproc*floor(1.*np/nproc)>=iproc)+&
(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc),mpi_double_precision,iproc,tag,mpi_comm_world,mpi_status,ierror)
enddo
else
tag=id+100
call mpi_send(df(id*floor(1.*np/nproc)+1+id*(np-nproc*floor(1.*np/nproc)>=id)+&
(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc)min((id+1)*floor(1.*np/nproc)+(id+1)*(np-nproc*floor(1.*np/nproc)>=id+1)&
+(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc),np-id*floor(1.*np/nproc)+1+id*(np-nproc*floor(1.*np/nproc)>=id)+&
(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc),mpi_double_precision,0,tag, mpi_comm_world,ierror)
endif
call mpi_bcast(df(1),np,mpi_double_precision,0,mpi_comm_world,ierror)
prevdf=df
if (id==0) print 9000, floor(currtime/3600) ,floor((currtime-floor(currtime/3600)*3600)/60),currtime-floor(currtime/60)*60
!! Initial guess of the hessian (identity matrix)
identity=0
impar=1
do ipar=1,nop
identity(impar,impar)=1.
impar=impar+1
enddo
ddf=identity
!! MAIN LOOP: DIRECTION-ALPHA-UPDATE PARAMETERS-UPDATE HESSIAN
iter=1
Main_loop: do iter=1,maxiter
!! Find the direction of minimization
tempdir(:,1)=-1.*matmul(ddf,df)
impar=1
do ipar=1,nop
if (move(ipar)==0) then
dir(ipar)=0
else
dir(ipar)=tempdir(impar,1)
impar=impar+1
endif
enddo
!! Line minimization
an=1
if (id==0) then
p0=p
call subroutine2(p0,func0,1)
endif
if (id==min(nproc-1,1)) then
p1=xn+an*dir
endif
call mpi_bcast(func0,1,mpi_double_precision,0,mpi_comm_world,ierror)
call mpi_bcast(func1,1,mpi_double_precision,min(nproc-1,1),mpi_comm_world,ierror)
if (id==0) then
write (3,3000) iter,func0, p0
print 3100, iter, floor(currtime/3600) ,floor((currtime-floor(currtime/3600)*3600)/60),currtime-floor(currtime/60)*60, func0, func1
endif
Line_min: do
if (id==0) then
p2=xn+(an+eps)*dir
endif
p3=xn+(an-eps)*dir
call subroutine2(p3,func3,1)
endif
if (id==min(nproc-1-1*(nproc==2),2)) then
p4=xn+(an+2*eps)*dir
call subroutine2(p4,func4,1)
endif
if (id==min(nproc-1,3)) then
p5=xn+(an-2*eps)*dir
call subroutine2(p5,func5,1)
endif
call mpi_bcast(func2,1,mpi_double_precision,0,mpi_comm_world,ierror)
call mpi_bcast(func3,1,mpi_double_precision,min(nproc-1,1),mpi_comm_world,ierror)
call mpi_bcast(func4,1,mpi_double_precision,min(nproc-1-1*(nproc==2),2),mpi_comm_world,ierror)
call mpi_bcast(func5,1,mpi_double_precision,min(nproc-1,3),mpi_comm_world,ierror)
adf=(func2-func3)/(2*eps)
addf=(func4-2*func1+func5)/(4*(eps**2))
an1=an-adf/addf
an=an1
if (id==0) then
p1=xn+an*dir
endif
call mpi_bcast(func1,1,mpi_double_precision,0,mpi_comm_world,ierror)
if (func1>func0+c1*an*dot_product(tempdir(:,1),prevdf)) cycle Line_min
if (id==0) then
print 4100, floor(currtime/3600) ,floor((currtime-floor(currtime/3600)*3600)/60),currtime-floor(currtime/60)*60, func1
endif
impar=1
! !$omp parallel do num_threads(1) default(none) private(p3,p4,func3,func4,impar,currtime,ipar) shared(xn,df,an,dir,y,nop,algorithm,globaltime,prevdf,move)
do ipar=1,nop
+(np-nproc*floor(1.*np/nproc))*(np-nproc*floor(1.*np/nproc)p3=xn+an*dir
p4=xn+an*dir
p3(ipar)=xn(ipar)+an*dir(ipar)+eps
print 2110, ipar, floor(currtime/3600) ,floor((currtime-floor(currtime/3600)*3600)/60),currtime-floor(currtime/60)*60, func3
p4(ipar)=xn(ipar)+an*dir(ipar)-eps
print 2111, ipar, floor(currtime/3600) ,floor((currtime-floor(currtime/3600)*3600)/60),currtime-floor(currtime/60)*60, func4
y(impar,1)=(func3-func4)/(2*eps)-prevdf(impar)
df(impar)=(func3-func4)/(2*eps)
endif
enddo
if (id==0) then
do iproc=1,nproc-1
tag=iproc+500
tag=iproc+5000
call mpi_recv(y(iproc*floor(1.*np/nproc)+1+iproc*(np-nproc*floor(1.*np/nproc)>=iproc)+&
enddo
else
tag=id+500
tag=id+5000
call mpi_send(y(id*floor(1.*np/nproc)+1+id*(np-nproc*floor(1.*np/nproc)>=id)+&
endif
call mpi_bcast(y(1,1),np,mpi_double_precision,0,mpi_comm_world,ierror)
if (abs(dot_product(tempdir(:,1),df))<=c2*abs(dot_product(tempdir(:,1),prevdf))) exit Line_min
enddo Line_min
prevdf=df
if (id==0) then
endif
!! Update parameters
xn1=xn+an1*dir
p=xn1
if (maxval(abs(xn1-xn))<=stopcr) exit Main_loop
xn=xn1
!! Update the hessian
outer=identity-(1/dot_product(y(:,1),an1*tempdir(:,1)))*matmul(y,transpose(an1*tempdir))
ddf=matmul(matmul(transpose(outer),ddf),outer)+(1/dot_product(y(:,1),an1*tempdir(:,1)))*matmul(an1*tempdir,transpose(an1*tempdir))
enddo Main_loop
!******* finalize mpi environment *******
call mpi_finalize(ierror)
1000 FORMAT (' BROYDEN_FLETCHER_GOLDFARB_SHANNO...' /&
' Iteration Func.value. Parameter values')
3000 FORMAT (' ', i6, ' ', f17.8, ' ', 105f20.10)
1100 FORMAT (' BROYDEN_FLETCHER_GOLDFARB_SHANNO...')
2100 FORMAT (' Computing the gradient at x0...')
2110 FORMAT (' First evaluation of parameter ', i3, ' at ',i4,':',i3,':',f6.2,' with value function ', f17.8)
2111 FORMAT (' Second evaluation of parameter ', i3, ' at ',i4,':',i3,':',f6.2,' with value function ', f17.8)
3100 FORMAT (' Iteration ', i6, ' started at ',i4,':',i3,':',f6.2,' with value functions ', f17.8, f17.8)
4100 FORMAT (' First Wolfe criterion met at ',i4,':',i3,':',f6.2, ' with value function', f17.8)
9000 FORMAT (' ... done at ',i4,':',i3,':',f6.2)
end subroutine
end module[/fortran]
Moreover, notice the following (strange) things:
  • I switch OpenMP and MPI by uncommenting omp lines and commenting mpi calls (and some if's)
  • The first (input) argument of subroutine2 is the vector of parameters; the second (output) is the evaluation of the function to be minimized (scalar) and the third one is a flag that determines the size of some arrays in subroutine2.
  • The code works properly with OpenMP (with 1 and 8 threads in an 8 core machine with 16G of ram).
  • It doesn't work with MPI even if I comment all MPI calls and I give all processes id=0 (so that all of them do the same). And it even doesn't work if I run with mpiexec -np 1 (i.e. with a single process), either with mpi calls commented and uncommented
  • Subroutine 1 works perfectly (either with OpenMP and MPI) to minimize the following function:
[fortran]
subroutine subroutine2(p,h,n1)
use readdata
implicit none
integer, parameter :: npar=105
real(8), intent(in) :: p(npar)
real(8), intent(out) :: h
integer, intent(in) :: n1
h=sum(p**2)+sum(p**4)
end subroutine
[/fortran]
  • I am not able to reproduce the error with simpler versions of the program
I hope it helps. Let me know about further details that may be necessary.
bellman
I hope this new edit helps in clarifying the issue. I finally came out with a simple program that replicates the error. Here it comes:
[fortran]module themodule
integer ::  algorithm
real ::  globaltime
integer, parameter ::  modnpar=105, modproc=8
integer, parameter ::  moddim1=-40, moddim2=107, moddim3=2, moddim4=4, moddim5=2
integer, parameter ::  moddim6=50, moddim7=4, moddim8=2, moddim9=67, moddim10=93
integer ::  gvar2, gvar3, gvar4, gvar5, gvar6
real ::  gvar7(moddim1:moddim2), gvar8(moddim1:moddim2), gvar9(moddim1:moddim2), gvar10(moddim1:moddim2,moddim6,moddim8,moddim5)
real ::  gvar11(moddim1:moddim2), gvar12(moddim1:moddim2,moddim6,moddim5), gvar13(moddim6,moddim5), gvar14(moddim1:moddim2)
integer ::  gvar15(moddim1:moddim2,8,moddim5,moddim8)
real ::  gvar16(0:2,0:2,moddim6,moddim5,moddim7,moddim1:moddim2), gvar17(moddim9:moddim2,moddim5,moddim6/5,moddim4-1)
real ::  gvar18(moddim9:moddim2,moddim5,moddim7,moddim4-1), gvar19(moddim9:moddim2,moddim5,0:2,moddim4-1)
real ::  gvar20(moddim10:moddim2,moddim5,moddim8,moddim4-1), gvar21(moddim10:moddim2,moddim5,5,moddim4-1)
real ::  gvar22(21,moddim5,0:1,moddim4-1), gvar23(10,moddim5,0:1,moddim4-1), gvar24(moddim5,5,5)
real ::  gvar25(moddim5,5,5), gvar26(moddim9:moddim2,moddim5,moddim6/5,moddim3)
real ::  gvar27(moddim9:moddim2,moddim5,moddim7,moddim3), gvar28(moddim10:moddim2,moddim5,moddim8,moddim3)
real ::  gvar29(moddim10:moddim2,moddim5,5,moddim3), gvar30(moddim5,5,5,moddim3), gvar31(moddim5,5,5,moddim3)
real ::  gvar32(moddim9:moddim2,moddim5,moddim3,moddim3), gvar33(moddim9:moddim2,moddim5,moddim6/5,moddim3)
real ::  gvar34(moddim10:moddim2,moddim5,moddim8,moddim3),gvar35(moddim10:moddim2,moddim5,5,moddim3)
real ::  gvar36(moddim9:moddim2,moddim5,moddim7,moddim3), gvar37(moddim10:moddim2,moddim5,moddim8,moddim3)
real ::  gvar38(moddim9:moddim2,moddim6/5,moddim5,moddim7-1), gvar39(moddim10:moddim2,moddim6/5,moddim8,moddim5,moddim7-1)
real ::  gvar40(moddim9:moddim2,moddim5,moddim4,moddim4-1), gvar41(moddim9:moddim2,moddim5,moddim4-(moddim3-1),moddim4-(moddim3-1)-1)
real ::  gvar42(moddim9:moddim2,moddim5,moddim6/5,moddim4,moddim4-1), gvar43(moddim10:moddim2,moddim5,moddim8,moddim4,moddim4-1)
real ::  gvar44(moddim10:moddim2,moddim5,moddim4-1), gvar45(moddim10:moddim2,moddim5,5,moddim4,moddim4-1)
real ::  gvar46(moddim5,0:13-1), gvar47(moddim5,0:7-1), gvar48(moddim5,0:13-1), gvar49(moddim5,0:7-1), gvar50(moddim5,0:13-1)
real ::  gvar51(moddim5,0:7-1), gvar52(moddim9:moddim2,moddim5,moddim6/5,moddim4-1), gvar53(moddim9:moddim2,moddim5,moddim7,moddim4-1)
real ::  gvar54(moddim9:moddim2,moddim5,0:2,moddim4-1), gvar55(moddim10:moddim2,moddim5,moddim8,moddim4-1)
real ::  gvar56(moddim10:moddim2,moddim5,5,moddim4-1), gvar57(21,moddim5,0:1,moddim4-1), gvar58(10,moddim5,0:1,moddim4-1)
real ::  gvar59(moddim5,5,5), gvar60(moddim5,5,5), gvar61(moddim9:moddim2,moddim5,moddim6/5,moddim3)
real ::  gvar62(moddim9:moddim2,moddim5,moddim7,moddim3), gvar63(moddim10:moddim2,moddim5,moddim8,moddim3)
real ::  gvar64(moddim10:moddim2,moddim5,5,moddim3), gvar65(moddim5,5,5,moddim3), gvar66(moddim5,5,5,moddim3)
real ::  gvar67(moddim9:moddim2,moddim5,moddim3,moddim3), gvar68(moddim9:moddim2,moddim5,moddim6/5,moddim3)
real ::  gvar69(moddim10:moddim2,moddim5,moddim8,moddim3), gvar70(moddim10:moddim2,moddim5,5,moddim3)
real ::  gvar71(moddim9:moddim2,moddim5,moddim7,moddim3),gvar72(moddim10:moddim2,moddim5,moddim8,moddim3)
real ::  gvar73(moddim9:moddim2,moddim6/5,moddim5,moddim7-1), gvar74(moddim10:moddim2,moddim6/5,moddim8,moddim5,moddim7-1)
real ::  gvar75(moddim9:moddim2,moddim5,moddim4,moddim4-1), gvar76(moddim9:moddim2,moddim5,moddim4-(moddim3-1),moddim4-(moddim3-1)-1)
real ::  gvar77(moddim9:moddim2,moddim5,moddim6/5,moddim4,moddim4-1), gvar78(moddim10:moddim2,moddim5,moddim8,moddim4,moddim4-1)
real ::  gvar79(moddim10:moddim2,moddim5,moddim4-1), gvar80(moddim10:moddim2,moddim5,5,moddim4,moddim4-1)
real ::  gvar81(moddim5,0:13-1), gvar82(moddim5,0:7-1), gvar83(moddim5,0:13-1),gvar84(moddim5,0:7-1)
real ::  gvar85(moddim5,0:13-1), gvar86(moddim5,0:7-1)
end module themodule
program something
use Quasi_Newton
use themodule
implicit none
real(8), parameter ::  stopcr=0.001
integer, parameter ::  maxfn=10000
real(8) :: p(npar)
integer :: whichpar(npar)
call kmp_set_stacksize(402653184)
algorithm=0
globaltime=secnds(0.0)
open(3,file='Output.txt')
p=1.
whichpar=1
call subroutine1(p,npar,sum(whichpar),whichpar,maxfn,stopcr)
end program
use omp_lib
use themodule
implicit none
real :: lvar1, lvar2
integer, parameter ::  npar=105, dim1=-40, dim2=107, dim3=2, dim4=4, dim5=2, dim6=2, dim7=50, dim8=4, dim9=2
integer, parameter ::  dim10=29, dim11=16, dim12=2000, dim13=2000, dim14=dim12+dim13, dim15=67, dim16=79, dim17=96
integer, parameter ::  dim18=93, dim19=90, dim20=93, dim21=103, dim22=106, dim23=15, dim24=17, dim25=8, dim26=10
integer ::  t, a, o, g, j, is, ipar, i1, i, k
real(8), intent(inout) ::  p(npar)
real ::  p1, p2, p3, p4, p5, p6, p7(2), p8(dim3,2*(dim3+1)+2), p9(dim3,dim5), p10(dim4,dim6,dim9,dim5)
real ::  p11(dim6,dim9,dim5,0:1), p12(7,dim5), p13(dim4,dim5), p14, p15(2), p16, p17(7,4)
real ::  svar1(dim1:dim2,dim3,n1),svar2(dim1:dim2,n1),svar3(dim7,dim11,dim4,dim5,dim6,dim9)
integer ::  svar4(dim14,dim7), svar5(dim14,dim7), svar6(dim14,dim7), svar7(dim14,dim7,dim3)
integer ::  svar8(dim14,dim7), svar9(dim14,dim7), svar10(dim14,dim7)
real ::  svar11(dim15:dim2,dim5,dim9,dim8,dim4), svar12(dim15:dim2,dim5,dim9,dim8,dim3), svar13(dim15:dim2,dim5,dim9,dim8)
real ::  svar14(dim15:dim2,dim5+1,dim9+1), svar15(dim1:dim2,dim3), svar16(dim15:dim2,dim5,dim7,dim4), svar17(dim15:dim2,dim5,dim8,dim4)
real ::  svar18(dim15:dim2,dim5,0:2,dim4), svar19(dim18:dim2,dim5,dim9,dim4), svar20(dim18:dim2,dim5,5,dim4), svar21(dim16:99,3,dim5,0:1,dim4)
real ::  svar22(dim17:106,5,dim5,0:1,dim4), svar23(dim16:94,dim5,5,5,dim3), svar24(dim17+2:106,dim5,5,5,dim3), svar25(dim15:dim2,dim5,dim7,dim3)
real ::  svar26(dim15:dim2,dim5,dim8,dim3), svar27(dim18:dim2,dim5,dim9,dim3), svar28(dim18:dim2,dim5,5,dim3), svar29(dim16:94,dim5,5,5,dim3)
real ::  svar30(dim17+2:106,dim5,5,5,dim3), svar31(dim15:dim2,dim5,dim3,dim3), svar32(dim15:dim2,dim5,2:dim7,dim3,dim3)
real ::  svar33(dim18:dim2,dim5,dim9,dim3,dim3), svar34(dim18:dim2,dim5,5,dim3,dim3), svar35(dim15:dim2,dim5,dim8,dim3)
real ::  svar36(dim18:dim2,dim5,dim9,dim3), svar37(dim15:dim2,dim7,dim5,dim8), svar38(dim18:dim2,dim7,dim9,dim5,dim8)
real ::  svar39(dim15:dim2,dim5,dim4,dim4), svar40(dim15:dim2,dim5,dim4-(dim3-1),dim4-(dim3-1)), svar41(dim15:dim2,dim5,dim7,dim4,dim4)
real ::  svar42(dim18:dim2,dim5,dim9,dim4,dim4), svar43(dim18:dim2,dim5,dim7,dim4), svar44(dim18:dim2,dim5,5,dim4,dim4)
real ::  svar45(dim19:dim20,dim23:dim24,dim5,0:13), svar46(dim21:dim22,dim25:dim26,dim5,0:7), svar47(dim19:dim20,dim23:dim24,dim5,0:13)
real ::  svar48(dim21:dim22,dim25:dim26,dim5,0:7), svar49(dim19:dim20,dim23:dim24,dim5,0:13), svar50(dim21:dim22,dim25:dim26,dim5,0:7)
integer :: svar51
ipar=0
p1=exp(p(ipar+1))/(1+exp(p(ipar+1)))
ipar=ipar+1
p2=exp(p(ipar+1))/(1+exp(p(ipar+1)))
ipar=ipar+1
p3=p(ipar+1)/10
ipar=ipar+1
p4=p(ipar+1)/10
ipar=ipar+1
p5=exp(p(ipar+1))/(1+exp(p(ipar+1)))
ipar=ipar+1
p6=exp(p(ipar+1))/(1+exp(p(ipar+1)))
ipar=ipar+1
p7=p(ipar+1:ipar+2)*10000
ipar=ipar+2
do o=1,dim3
p8(o,:)=p(ipar+1:ipar+2*(dim3+1)+2)
ipar=ipar+2*(dim3+1)+2
enddo
p8(1,1)=p8(1,1)/100
p8(1,2)=p8(1,2)/100
p8(1,3)=p8(1,3)/100
p8(1,4)=p8(1,4)/1000
p8(1,5)=p8(1,5)/1000
p8(1,6)=p8(1,6)/10
p8(1,7)=p8(1,7)/1000
p8(1,8)=p8(1,8)/100
p8(2,1)=p8(2,1)/10
p8(2,2)=p8(2,2)/100
p8(2,3)=p8(2,3)/100
p8(2,4)=p8(2,4)/1000
p8(2,5)=p8(2,5)/1000
p8(2,6)=p8(2,6)/10
p8(2,7)=p8(2,7)/100
p8(2,8)=p8(2,8)/100
do g=1,dim5
p9(:,g)=p(ipar+1:ipar+dim3)
ipar=ipar+dim3
enddo
p9=p9*10000
p10(1:2,1,1,1)=0
p10(3:4,1,1,1)=p(ipar+1:ipar+2)
ipar=ipar+2
p10(:,2,1,1)=p(ipar+1:ipar+dim4)
ipar=ipar+dim4
do k=1,dim6
p10(:,k,2,1)=p(ipar+1:ipar+dim4)
ipar=ipar+dim4
enddo
p10(:,1,1,2)=p(ipar+1:ipar+dim4)
ipar=ipar+dim4
p10(1:2,2,1,2)=p10(1:2,1,1,2)+(p10(1:2,2,1,1)-p10(1:2,1,1,1))
p10(3:4,2,1,2)=p10(3:4,1,1,2)*p10(3:4,2,1,1)/p10(3:4,1,1,1)
do k=1,dim6
p10(1:2,k,2,2)=p10(1:2,1,1,2)+(p10(1:2,k,2,1)-p10(1:2,1,1,1))
p10(3:4,k,2,2)=p10(3:4,1,1,2)*p10(3:4,k,2,1)/p10(3:4,1,1,1)
enddo
p10(1:2,:,:,:)=p10(1:2,:,:,:)/10
p10(3:4,:,:,:)=p10(3:4,:,:,:)*10000
do i=0,1; do is=1,dim9; do g=1,dim5; do k=1,dim6-1
p11(k,is,g,i)=exp(p(ipar+1))/(1+exp(p(ipar+1)))
ipar=ipar+1
enddo; enddo; enddo; enddo
forall (i=0:1,is=1:dim9,g=1:dim5) p11(dim6,is,g,i)=1-sum(p11(1:dim6-1,is,g,i))
p12(1,1)=0
p12(1,2)=p(ipar+1)
ipar=ipar+1
do i=2,7
p12(i,:)=p(ipar+1:ipar+dim5)
ipar=ipar+dim5
enddo
p12=p12*10000
p12(5,:)=p12(5,:)/100000
do g=1,dim5
p13(:,g)=p(ipar+1:ipar+dim4)
ipar=ipar+dim4
enddo
p13(1:2,:)=exp(p13(1:2,:))/10
p13(3:4,:)=exp(p13(3:4,:))*1000
p14=2*exp(p(ipar+1))/(1+exp(p(ipar+1)))-1
ipar=ipar+1
p15=p(ipar+1:ipar+2)
ipar=ipar+2
p16=p(ipar+1)
ipar=ipar+1
p17=0
p17(1:6,1)=p(ipar+1:ipar+6)
ipar=ipar+6
p17(1:6,2)=p(ipar+1:ipar+6)
ipar=ipar+6
p17(:,3)=p(ipar+1:ipar+7)
ipar=ipar+7
p17(:,4)=p(ipar+1:ipar+7)
ipar=ipar+7
do i1=1,n1
svar3=0
print *, 'hello1'
call subroutine3(p1, p2, p3, p4, p5, p6, p7, p8, p10, p12, p13, p14, p17, p15, p16, svar3)
print *, 'hello2'
call subroutine4(i1,svar4,svar5,svar6,svar7,svar8,svar9,svar10,p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p13,p14&
,svar3,p15,p17,p16,svar1,svar2,n1,svar51,svar16,svar17,svar18,svar19,svar20,svar21,svar22,svar23,svar24,svar25&
,svar26,svar27,svar28,svar29,svar30,svar31,svar32,svar33,svar34,svar35,svar36,svar37,svar38,svar39,svar40,svar41&
,svar42,svar43,svar44,svar45,svar46,svar47,svar48,svar49,svar50,svar11,svar12,svar13,svar14,svar15)
enddo
end subroutine subroutine2
subroutine subroutine3(p1, p2, p3, p4, p5, p6, p7, p8, p10, p12, p13, p14, p17, p15, p16, svar3)
use themodule
use omp_lib
implicit none
integer, parameter ::  dim1=-40, dim2=107, dim7=50, dim8=4, dim3=2, dim4=4, dim5=2, dim6=2, dim9=2, dim27=2000, dim28=1500, dim11=16, dim29=dim11-1
integer ::  o, c, g, k, a, is, c1, i, c2
real, intent(in) ::  p1, p2, p3, p4, p5, p6, p7(2), p8(dim3,2*(dim3+1)+2), p10(dim4,dim6,dim9,dim5)
real, intent(in) ::  p12(7,dim5), p13(dim4,dim5), p14, p15(2), p16, p17(7,4)
real ::  svar52(0:2,0:2,dim7,dim5,dim8,dim1:dim2), svar53(dim1:dim2), svar54(dim27,dim4,dim5,dim6,dim9), svar55(dim27,dim11)
real ::  lvar1(dim27,dim4,dim5,dim6,dim9), lvar2(dim27,dim4,dim4,dim5,dim6,dim9), lvar3(dim27,dim4,dim5,dim6,dim9)
real ::  lvar4(dim29,dim29), lvar5(dim11,dim11), lvar6(dim11,dim27)
real, allocatable ::  lvar7(:,:,:,:,:), lvar8(:,:,:,:,:)
real, intent(out) ::  svar3(dim7,dim11,dim4,dim5,dim6,dim9)
integer ::  svar56(dim27), svar57(dim27), svar58(dim27), svar59(dim27), svar60(dim27,dim4), svar61(dim27,dim4), svar62(dim27,dim3,dim9)
integer ::  svar63(dim27,dim3,dim9,dim4), svar64(dim27), svar65(dim27), svar67(dim27,dim5), svar68(dim27)
real ::  svar69(dim27,dim4), svar70(dim27), svar71(dim27), svar72(dim27), svar73(dim27,dim3), svar74(dim27,dim3), svar75(dim27,dim3)
real ::  svar76(dim27,2), svar77(dim27,2), svar78(dim27,2), svar79(dim27), svar80(dim27), svar81(dim27,dim3), svar82(dim27,dim6,dim9,dim5,dim3)
real ::  svar83(dim27,2), svar84(dim27,dim3), svar85(dim27), svar86(dim27), svar87(dim27)
print *, 'hi1'
!$omp critical
svar52=gvar16
svar53=gvar11
!$omp end critical
do a=dim7,2,(-1)
call subroutine5(svar53, p1, p2, p3, p4, p5, svar56, svar59, svar57, svar60, svar58, svar61, svar64, &
svar62, svar63, svar65, svar68, svar71, svar72, svar75, svar74, svar78, svar77, svar80, svar86, svar87, a)
lvar2=-10.
lvar3=0.
do c1=1,dim28
call subroutine6(svar52, p17, p15, p16, p1, p2, p3, p4, p5, svar56, svar58, svar68, &
svar71, svar72, svar75, svar74, svar78, svar77, svar80, svar67, svar69, svar70, svar73, svar76, svar79, svar81, a)
call subroutine7(svar52, p1, p2, p3, p4, p5, p17, p15, svar56+1, svar60, svar61, svar64, svar65, svar63, svar67, svar70, svar85, svar84, svar73, svar83, svar76, svar79, svar87, a+1, svar3, svar54)
enddo
if (a<=35) then
do g=1,dim5
call subroutine8(svar52, p1, p2, p3, p4, p5, p17, p15, svar56, svar57, svar58, svar64, svar65, svar62, svar68, svar71, svar72, svar75, svar74, svar78, svar77, svar80, svar86, a, svar55, g, 1)
enddo
do g=1,dim5
call subroutine8(svar52, p1, p2, p3, p4, p5, p17, p15, svar56, svar57, svar58, svar64, svar65, svar62, svar68, svar71, svar72, svar75, svar74, svar78, svar77, svar80, svar86, a, svar55, g, 2)
enddo
elseif (a>35) then
do g=1,dim5
if (g==1) then
endif
enddo
do g=1,dim5
if (g==1) then
endif
enddo
endif
svar3=10.
enddo
end subroutine subroutine3
subroutine subroutine4(i1,svar4,svar5,svar6,svar7,svar8,svar9,svar10,p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p13,p14&
implicit none
integer, parameter ::  dim1=-40, dim2=107, dim3=2, dim4=4, dim5=2, dim6=2, dim7=50, dim8=4, dim9=2, dim11=16, dim12=2000
integer, parameter ::  dim13=2000, dim14=dim12+dim13, dim31=30, dim15=67, dim16=79, dim17=96, dim18=93, dim30=dim1, dim19=90
integer, parameter ::  dim20=93, dim21=103, dim22=106, dim23=15, dim24=17, dim25=8, dim26=10
integer, intent(in) ::  n1, i1
integer ::  t, o, c, g, a, e, is, i, j, c3, c4, ipar
real, intent(in) ::  p1, p2, p3, p4,p5, p6, p7(2), p8(dim3,2*(dim3+1)+2), p9(dim3,dim5)
real, intent(in) ::  p10(dim4,dim6,dim9,dim5), p11(dim6,dim9,dim5,0:1), p12(7,dim5), p13(dim4,dim5), p14
real, intent(inout) ::  p15(2), p16, p17(7,4)
real, intent(out) ::  svar15(dim1:dim2,dim3)
real, intent(inout) ::  svar1(dim1:dim2,dim3,n1), svar2(dim1:dim2,n1)
integer, intent(inout) ::  svar4(dim14,dim7), svar5(dim14,dim7), svar6(dim14,dim7), svar7(dim14,dim7,dim3)
integer, intent(inout) ::  svar8(dim14,dim7), svar9(dim14,dim7),  svar10(dim14,dim7)
real, intent(in) ::  svar3(dim7,dim11,dim4,dim5,dim6,dim9)
real, intent(out) ::  svar11(dim15:dim2,dim5,dim9,dim8,dim4), svar12(dim15:dim2,dim5,dim9,dim8,dim3), svar13(dim15:dim2,dim5,dim9,dim8)
real, intent(out) ::  svar14(dim15:dim2,dim5+1,dim9+1), svar16(dim15:dim2,dim5,dim7,dim4), svar17(dim15:dim2,dim5,dim8,dim4)
real, intent(out) ::  svar18(dim15:dim2,dim5,0:2,dim4), svar19(dim18:dim2,dim5,dim9,dim4), svar20(dim18:dim2,dim5,5,dim4)
real, intent(out) ::  svar21(dim16:99,3,dim5,0:1,dim4), svar22(dim17:106,5,dim5,0:1,dim4), svar23(dim16:94,dim5,5,5,dim3)
real, intent(out) ::  svar24(dim17+2:106,dim5,5,5,dim3), svar25(dim15:dim2,dim5,dim7,dim3), svar26(dim15:dim2,dim5,dim8,dim3)
real, intent(out) ::  svar27(dim18:dim2,dim5,dim9,dim3), svar28(dim18:dim2,dim5,5,dim3), svar29(dim16:94,dim5,5,5,dim3)
real, intent(out) ::  svar30(dim17+2:106,dim5,5,5,dim3), svar31(dim15:dim2,dim5,dim3,dim3), svar32(dim15:dim2,dim5,2:dim7,dim3,dim3)
real, intent(out) ::  svar33(dim18:dim2,dim5,dim9,dim3,dim3), svar34(dim18:dim2,dim5,5,dim3,dim3), svar35(dim15:dim2,dim5,dim8,dim3)
real, intent(out) ::  svar36(dim18:dim2,dim5,dim9,dim3), svar37(dim15:dim2,dim7,dim5,dim8), svar38(dim18:dim2,dim7,dim9,dim5,dim8)
real, intent(out) ::  svar39(dim15:dim2,dim5,dim4,dim4), svar40(dim15:dim2,dim5,dim4-(dim3-1),dim4-(dim3-1)), svar41(dim15:dim2,dim5,dim7,dim4,dim4)
real, intent(out) ::  svar42(dim18:dim2,dim5,dim9,dim4,dim4), svar43(dim18:dim2,dim5,dim7,dim4), svar44(dim18:dim2,dim5,5,dim4,dim4)
real, intent(out) ::  svar45(dim19:dim20,dim23:dim24,dim5,0:13), svar46(dim21:dim22,dim25:dim26,dim5,0:7), svar47(dim19:dim20,dim23:dim24,dim5,0:13)
real, intent(out) ::  svar48(dim21:dim22,dim25:dim26,dim5,0:7), svar49(dim19:dim20,dim23:dim24,dim5,0:13), svar50(dim21:dim22,dim25:dim26,dim5,0:7)
integer ::  svar51
real ::  lvar1(2)
integer ::  lvar2(dim7,dim5), lvar3(dim14,dim7), lvar4(dim14,dim7), lvar5(dim14,dim7), lvar6(dim14,dim7,dim4), lvar7(dim14,dim7,dim4)
integer ::  lvar8(dim14,dim7,dim3), lvar9(dim14,dim7), lvar10(dim14,dim7,dim3,dim4), lvar11(dim14,dim7), lvar12(dim14,dim7)
integer ::  lvar13(dim14,dim7), lvar14(dim14), lvar15(dim14), lvar16(dim14,dim7), lvar17(dim14,dim7)
real(8) ::  lvar18(dim14,dim7,dim4)
real ::  lvar19(dim1:dim2), lvar20(dim1:dim2), lvar21(dim1:dim2), lvar22(dim1:dim2,dim3,dim31+1)
real, parameter ::  lvar23=5
real ::  lvar24(dim14,dim7), lvar25(dim14,dim7,dim3), lvar26(dim14,dim7,dim3), lvar27(dim14,dim7,dim3)
real ::  lvar28(dim14,dim7,dim4), lvar29(dim14,dim7,dim4),  lvar32(dim14,dim7,dim4), lvar33
integer ::  lvar30(dim14,dim7), lvar31(dim14,dim7), lvar36
real, parameter ::  lvar34=0.01
integer, parameter :: lvar37=8.5, lvar38=1+size(p15)+size(p17)-2
real ::  lvar39(lvar38), lvar40(lvar38), lvar41(lvar38)
real(8), parameter :: lvar42=0, lvar43=1
real, parameter :: lvar44=0, lvar45=1
real :: lvar46(dim1:dim2,2), lvar47(dim1:dim2), lvar48(dim1:dim2,dim7,dim9,dim5),lvar49(dim1:dim2), lvar50(0:2,0:2,dim7,dim5,dim8,dim1:dim2)
real :: lvar51(dim1:dim2), lvar52(dim1:dim2,2),lvar53(dim1:dim2),lvar54(dim1:dim2,dim3)
print *, 'Hi2'
svar15=10.
svar1=10.
svar2=10.
svar4=10
svar5=10
svar6=10
svar7=10
svar8=10
svar9=10
svar10=10
svar11=10.
svar12=10.
svar13=10.
svar14=10.
svar16=10.
svar17=10.
svar18=10.
svar19=10.
svar20=10.
svar21=10.
svar22=10.
svar23=10.
svar24=10.
svar25=10.
svar26=10.
svar27=10.
svar28=10.
svar29=10.
svar30=10.
svar31=10.
svar32=10.
svar33=10.
svar34=10.
svar35=10.
svar36=10.
svar37=10.
svar38=10.
svar39=10.
svar40=10.
svar41=10.
svar42=10.
svar43=10.
svar44=10.
svar45=10.
svar46=10.
svar47=10.
svar48=10.
svar49=10.
svar50=10.
end subroutine subroutine4
subroutine subroutine5(svar53, p1, p2, p3, p4, p5, svar56, svar59, svar57, svar60, svar58, svar61, svar64, &
implicit none
integer, parameter ::  dim1=-40,dim2=107, dim3=2, dim9=2, dim27=2000, dim4=4
integer, intent(in) ::  a
integer ::  c2, o, c
integer, intent(out) ::  svar56(dim27), svar59(dim27), svar57(dim27), svar60(dim27,dim4), svar58(dim27), svar61(dim27,dim4)
integer, intent(out) ::  svar64(dim27), svar62(dim27,dim3,dim9), svar63(dim27,dim3,dim9,dim4), svar65(dim27), svar68(dim27)
real, intent(out) ::  svar71(dim27), svar72(dim27), svar74(dim27,dim3), svar75(dim27,dim3), svar77(dim27,2), svar78(dim27,2)
real, intent(out) ::  svar80(dim27), svar86(dim27), svar87(dim27)
real, intent(in) ::  p1, p2, p3, p4, p5, svar53(dim1:dim2)
real ::  lvar1(dim27), lvar2(dim27), lvar3(dim27), lvar4(dim27), lvar5(dim27,dim3+1), lvar6(dim27), lvar7(dim27), lvar8(dim27), lvar9(dim27)
real, parameter :: lvar10=0., lvar11=1.
svar56=10
svar59=10
svar57=10
svar60=10
svar58=10
svar61=10
svar64=10
svar62=10
svar63=10
svar65=10
svar68=10
svar71=10.
svar72=10.
svar74=10.
svar75=10.
svar77=10.
svar78=10.
svar80=10.
svar86=10.
svar87=10.
end subroutine subroutine5
subroutine subroutine6(svar52, p17, p15, p16, p1, p2, p3, p4, p5, svar56, svar58, svar68, &
implicit none
integer, parameter ::  dim1=-40, dim2=107, dim7=50, dim8=4, dim5=2, dim9=2, dim4=4, dim3=2, dim27=2000
integer ::  c2, c, o, g, i
integer, intent(in) ::  svar56(dim27), svar58(dim27), svar68(dim27)
real, intent(in) ::  svar71(dim27), svar72(dim27), svar74(dim27,dim3), svar75(dim27,dim3), svar78(dim27,2), svar80(dim27), svar77(dim27,2)
integer, intent(out) ::  svar67(dim27,dim5)
real, intent(out) ::  svar69(dim27,dim4), svar70(dim27), svar73(dim27,dim3), svar76(dim27,2), svar79(dim27), svar81(dim27,dim3)
real, intent(in) ::  p1, p2, p3, p4, p5, p15(2), p16, p17(7,4), svar52(0:2,0:2,dim7,dim5,dim8,dim1:dim2)
real(8) ::  lvar2(dim27,dim4), lvar3(dim27), lvar4(dim27)
real, parameter ::  lvar5=0.9559713, lvar6=0.00925
real(8), parameter :: lvar7=0., lvar8=1.
real, parameter :: lvar9=0., lvar10=1.
real :: lvar11(dim27), lvar12(dim27)
svar67=10
svar69=10.
svar70=10.
svar73=10.
svar76=10.
svar79=10.
svar81=10.
end subroutine subroutine6
subroutine subroutine7(svar52, p1, p2, p3, p4, p5, p17, p15, svar56, svar57, svar58, svar64, svar65, svar62, svar68, svar71, svar72, svar75, svar74, svar78, svar77, svar80,svar86, a, svar3, svar54)
implicit none
integer, parameter ::  dim1=-40, dim2=107, dim7=50, dim8=4, dim5=2, dim3=2, dim4=4, dim6=2, dim9=2, dim27=2000, dim11=16
integer, intent(in) :: svar56(dim27), svar64(dim27), svar65(dim27), svar68(dim27,dim5), svar62(dim27,dim3,dim9,dim4), svar57(dim27,dim4), svar58(dim27,dim4)
real, intent(in) ::  svar71(dim27), svar72(dim27), svar74(dim27,dim3), svar75(dim27,dim3), svar77(dim27,2), svar78(dim27,2)
real, intent(in) ::  svar80(dim27), svar86(dim27), svar3(dim7,dim11,dim4,dim5,dim6,dim9), svar52(0:2,0:2,dim7,dim5,dim8,dim1:dim2)
real, intent(in) ::  p1, p2, p3, p4, p5, p15(2), p17(7,4)
real, intent(out) ::  svar54(dim27,dim4,dim5,dim6,dim9)
integer :: iss, i, j, o, c, is, g, c2
real :: lvar1(dim27,dim11), lvar2(dim27,2), lvar3(dim27,dim3), lvar4(dim27), lvar5(dim27), lvar6(dim27), lvar7(dim27,dim3), lvar8(dim27)
real, parameter ::  lvar9=0.9559713
svar54=10
end subroutine subroutine7
subroutine subroutine8(svar52, p1, p2, p3, p4, p5, p17, p15, svar56, svar57, svar58, svar64, svar65, svar62, svar68, svar71, svar72, svar75, svar74, svar78, svar77, svar80, svar86, a, svar55, g, is)
implicit none
integer, parameter ::  dim1=-40, dim2=107, dim7=50, dim8=4, dim5=2, dim3=2, dim9=2, dim27=2000, dim11=16
integer, intent(in) ::  a, is, g
integer, intent(in) ::  svar56(dim27), svar57(dim27), svar58(dim27), svar62(dim27,dim3,dim9), svar68(dim27), svar64(dim27), svar65(dim27)
real, intent(in) ::  svar71(dim27), svar77(dim27,2), svar80(dim27), svar74(dim27,dim3), svar72(dim27), svar75(dim27,dim3), svar78(dim27,2)
real, intent(in) ::  svar52(0:2,0:2,dim7,dim5,dim8,dim1:dim2), svar86(dim27)
real, intent(in) ::  p1,p2,p3,p4,p5, p15(2), p17(7,4)
real :: lvar1(dim27,2), lvar2(dim27,dim3), lvar3(dim27), lvar4(dim27), lvar5(dim27), lvar6(dim27,dim3), lvar7(dim27)
real, parameter ::  lvar8=0.9559713
real, intent(out) :: svar55(dim27,dim11)
integer :: iss, j, o, c2, i
svar55=10.
end subroutine subroutine8
[/fortran]
This piece of code together with the code of subroutine1 posted above replicates the error I get. Moreover, if I comment a piece of code (a call to a subroutine, or one the definitions of some variable such lvar2 and lvar3 at the beginning of subroutine2) then the program works fine. In sum, if I run the code with mpiexec -np 1 ./aaa it doesn't work and if I simply ./aaa then it works.
Thanks again for your help and sorry for the so long post!
atom2626
I didn't had the time to look at your code, but maybe this will help you. OpenMP is a shared memory library it means that all thread have access to the same memory space (single computer, multi-core). MPI runs on a cluster and memory content can only beexchanged through messaging.
Segmentation fault is an invalid memory access like an invalid pointer oran overflowing buffer, look in this direction.
Since the bug is in memory, OpenMP and MPI address different systems configuration at the memory level, it is possible that youralgorithm works in one and not the other.
Good Luck,
Fred
Dmitry_K_Intel2
Hi Bellman,
You could try to use debugger to find out the reason of the SegFault. It's quite easy 'mpirun -gdb -np 1 ./aaa'.
Oh, as alternative solution, you could try Valgrind.
Regards!
Dmitry
bellman
Many thanks to both of you for replying.
I followed Dmitry's suggestion and used Valgrind. It seems that it says that something is wrong, but I really don't understand the output. I will keep trying to understand it on my own, but here it is the output in case it helps to solve the issue. Many thanks again for your help!
[plain]==5843== Memcheck, a memory error detector.
==5843== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
==5843== Using LibVEX rev 1854, a library for dynamic binary translation.
==5843== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
==5843== Using valgrind-3.3.1-Debian, a dynamic binary instrumentation framework.
==5843== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
==5843== For more details, rerun with: -v
==5843==
==5845==
==5845== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 16 from 2)
==5845== malloc/free: in use at exit: 594,506 bytes in 38 blocks.
==5845== malloc/free: 189 allocs, 151 frees, 625,873 bytes allocated.
==5845== For counts of detected errors, rerun with: -v
==5845== searching for pointers to 38 not-freed blocks.
==5845== checked 313,448 bytes.
==5845==
==5845== 11 bytes in 1 blocks are definitely lost in loss record 2 of 7
==5845==    at 0x4C2260E: malloc (vg_replace_malloc.c:207)
==5845==    by 0x402CB5B: disrst (disrst.c:133)
==5845==    by 0x40385F2: tm_poll (tm.c:1488)
==5845==    by 0x40391F6: tm_init (tm.c:713)
==5845==    by 0x404D89: get_hosts (get_hosts.c:83)
==5845==    by 0x40333C: main (mpiexec.c:678)
==5845==
==5845== LEAK SUMMARY:
==5845==    definitely lost: 11 bytes in 1 blocks.
==5845==      possibly lost: 0 bytes in 0 blocks.
==5845==    still reachable: 594,495 bytes in 37 blocks.
==5845==         suppressed: 0 bytes in 0 blocks.
==5845== Reachable blocks (those to which a pointer was found) are not shown.
==5845== To see them, rerun with: --leak-check=full --show-reachable=yes
mpiexec: Warning: task 0 died with signal 11 (Segmentation fault).
==5843==
==5843== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 16 from 2)
==5843== malloc/free: in use at exit: 1,058,636 bytes in 27 blocks.
==5843== malloc/free: 152 allocs, 125 frees, 1,087,615 bytes allocated.
==5843== For counts of detected errors, rerun with: -v
==5843== searching for pointers to 27 not-freed blocks.
==5843== checked 292,640 bytes.
==5843==
==5843== 11 bytes in 1 blocks are definitely lost in loss record 2 of 9
==5843==    at 0x4C2260E: malloc (vg_replace_malloc.c:207)
==5843==    by 0x402CB5B: disrst (disrst.c:133)
==5843==    by 0x40385F2: tm_poll (tm.c:1488)
==5843==    by 0x40391F6: tm_init (tm.c:713)
==5843==    by 0x404D89: get_hosts (get_hosts.c:83)
==5843==    by 0x40333C: main (mpiexec.c:678)
==5843==
==5843==
==5843== 280 (240 direct, 40 indirect) bytes in 1 blocks are definitely lost in loss record 7 of 9
==5843==    by 0x407C6D: Malloc (util.c:281)
==5843==    by 0x4039C8: main (mpiexec.c:918)
==5843==
==5843== LEAK SUMMARY:
==5843==    definitely lost: 251 bytes in 2 blocks.
==5843==    indirectly lost: 40 bytes in 1 blocks.
==5843==      possibly lost: 0 bytes in 0 blocks.
==5843==    still reachable: 1,058,345 bytes in 24 blocks.
==5843==         suppressed: 0 bytes in 0 blocks.
==5843== Reachable blocks (those to which a pointer was found) are not shown.
==5843== To see them, rerun with: --leak-check=full --show-reachable=yes
[/plain]
