Intel® MPI Library
2275 Discussions
Sending sub-arrays of matrix to different processors using mpi_scatterv
Siva_Srinivas_K_
I want to scatter matrix from root to other processors using scatterv. I am creating a communicator topology using mpi_cart_create. As an example I have the below code in fortran:
PROGRAM SendRecv
USE mpi
IMPLICIT none
integer, PARAMETER :: m = 4, n = 4
integer, DIMENSION(m,n) :: a, b,h
integer :: i,j,count
integer,allocatable, dimension(:,:):: loc   ! local piece of global 2d array
INTEGER :: istatus(MPI_STATUS_SIZE),ierr
integer, dimension(2) :: sizes, subsizes, starts
INTEGER :: ista,iend,jsta,jend,ilen,jlen
INTEGER :: iprocs, jprocs, nprocs
integer,allocatable,dimension(:):: rcounts, displs
INTEGER :: rcounts0,displs0
integer, PARAMETER :: ROOT = 0
integer :: dims(2),coords(2)
logical :: periods(2)
data  periods/2*.false./
integer :: status(MPI_STATUS_SIZE)
integer :: comm2d,source,myrank
integer :: newtype, resizedtype
integer :: comsize,charsize
integer(kind=MPI_ADDRESS_KIND) :: extent, begin
CALL MPI_INIT(ierr)
CALL MPI_COMM_SIZE(MPI_COMM_WORLD, nprocs, ierr)
CALL MPI_COMM_RANK(MPI_COMM_WORLD, myrank, ierr)
! Get a new communicator for a decomposition of the domain.
dims(1) = 0
dims(2) = 0
CALL MPI_DIMS_CREATE(nprocs,2,dims,ierr)
if (myrank.EQ.Root) then
   print *,nprocs,'processors have been arranged into',dims(1),'X',dims(2),'grid'
endif
CALL MPI_CART_CREATE(MPI_COMM_WORLD,2,dims,periods,.true., &
                  comm2d,ierr)
!   Get my position in this communicator
CALL MPI_COMM_RANK(comm2d,myrank,ierr)
! Get the decomposition
CALL fnd2ddecomp(comm2d,m,n,ista,iend,jsta,jend)
! print *,ista,jsta,iend,jend
ilen = iend - ista + 1
jlen = jend - jsta + 1
CALL MPI_Cart_get(comm2d,2,dims,periods,coords,ierr)
iprocs = dims(1)
jprocs = dims(2)
! define the global matrix
if (myrank==ROOT) then
   count = 0
    do j = 1,n
       do i = 1,m
          a(i,j) = count
          count = count+1
       enddo
    enddo
    print *, 'global matrix is: '
    do 90 i=1,m
       do 80 j = 1,n
           write(*,70)a(i,j)
    70     format(2x,I5,$)
    80     continue
           print *, ' '
  90    continue
endif
call MPI_Barrier(MPI_COMM_WORLD, ierr)
starts   = [0,0]
sizes    = [m, n]
subsizes = [ilen, jlen]
call MPI_Type_create_subarray(2, sizes, subsizes, starts,        &
                               MPI_ORDER_FORTRAN, MPI_INTEGER,  &
                               newtype, ierr)
call MPI_Type_size(MPI_INTEGER, charsize, ierr)
begin  = 0
extent = charsize
call MPI_Type_create_resized(newtype, begin, extent, resizedtype, ierr)
call MPI_Type_commit(resizedtype, ierr)
! get counts and displacmeents
allocate(rcounts(nprocs),displs(nprocs))
rcounts0 = 1
displs0 = (ista-1) + (jsta-1)*m
CALL MPI_Allgather(rcounts0,1,MPI_INT,rcounts,1,MPI_INT,MPI_COMM_WORLD,IERR)
CALL MPI_Allgather(displs0,1,MPI_INT,displs,1,MPI_INT,MPI_COMM_WORLD,IERR)
CALL MPI_Barrier(MPI_COMM_WORLD, ierr)
! scatter data
allocate(loc(ilen,jlen))
call MPI_Scatterv(a,rcounts,displs,resizedtype,    &
                 loc,ilen*jlen,MPI_INTEGER, &
                  ROOT,MPI_COMM_WORLD,ierr)
! print each processor matrix
do source = 0,nprocs-1
   if (myrank.eq.source) then
       print *,'myrank:',source
       do i=1,ilen
           do j = 1,jlen
              write(*,701)loc(i,j)
701               format(2x,I5,$)
           enddo
       print *, ' '
       enddo
    endif
enddo
call MPI_Type_free(newtype,ierr)
call MPI_Type_free(resizedtype,ierr)
deallocate(rcounts,displs)
deallocate(loc)
CALL MPI_FINALIZE(ierr)
contains
subroutine fnd2ddecomp(comm2d,m,n,ista,iend,jsta,jend)
integer   comm2d
integer   m,n,ista,jsta,iend,jend
integer   dims(2),coords(2),ierr
logical   periods(2)
! Get (i,j) position of a processor from Cartesian topology.
! Decomposition in first (ie. X) direction
CALL MPE_DECOMP1D(m,dims(1),coords(1),ista,iend)
! Decomposition in second (ie. Y) direction
CALL MPE_DECOMP1D(n,dims(2),coords(2),jsta,jend)
end subroutine fnd2ddecomp
SUBROUTINE MPE_DECOMP1D(n,numprocs,myid,s,e)
integer n,numprocs,myid,s,e,nlocal,deficit
nlocal  = n / numprocs
s       = myid * nlocal + 1
deficit = mod(n,numprocs)
s       = s + min(myid,deficit)
! Give one more slice to processors
if (myid .lt. deficit) then
    nlocal = nlocal + 1
endif
e = s + nlocal - 1
if (e .gt. n .or. myid .eq. numprocs-1) e = n
end subroutine MPE_DECOMP1D
END program SendRecv
I am generating a 4x4 matrix, and using scatterv I am sending the blocks of matrices to other processors. Code works fine for 4,2 and 16 processors. But throws a error for three processors. What modifications I have to do make it work for any number of given processors.
Global matrix in Root:
[ 0      4      8     12
  1      5      9     13
  2      6     10     14
  3      7     11     15 ]
For 4 processors each processors gets.
Rank =0 : [0 4
          1 5]
Rank =1 : [8 12
          9 13]
Rank =2 : [2 6
          3 7]
Rank =3 : [10 14
          11 15]
Code works for 2 and 16 processors; in fact it works when sub-arrays are of similar size. It fails for 3 processors. For 3 processors I am expecting:
Rank =0 : [0 4 8 12
           1 5 9 13]
Rank =1 : [2 6 10 14]
Rank =2 : [3 7 11 15]
But I am getting the following error:
Fatal error in PMPI_Scatterv: Message truncated, error stack:
PMPI_Scatterv(671)................: MPI_Scatterv(sbuf=0x6b58c0, scnts=0xf95d90, displs=0xfafbe0, dtype=USER<resized>, rbuf=0xfafc00, rcount=4, MPI_INTEGER, root=0, MPI_COMM_WORLD) failed
MPIR_Scatterv_impl(211)...........:
I_MPIR_Scatterv_intra(278)........: Failure during collective
I_MPIR_Scatterv_intra(272)........:
MPIR_Scatterv(147)................:
MPIDI_CH3U_Receive_data_found(131): Message from rank 0 and tag 6 truncated; 32 bytes received but buffer size is 16
PMPI_Scatterv(671)................: MPI_Scatterv(sbuf=0x6b58c0, scnts=0x240bda0, displs=0x240be60, dtype=USER<resized>, rbuf=0x240be80, rcount=4, MPI_INTEGER, root=0, MPI_COMM_WORLD) failed
forrtl: error (69): process interrupted (SIGINT)
Image              PC                Routine            Line        Source
a.out              0000000000479165  Unknown               Unknown  Unknown
a.out              0000000000476D87  Unknown               Unknown  Unknown
a.out              000000000044B7C4  Unknown               Unknown  Unknown
a.out              000000000044B5D6  Unknown               Unknown  Unknown
a.out              000000000042DB76  Unknown               Unknown  Unknown
a.out              00000000004053DE  Unknown               Unknown  Unknown
libpthread.so.0    00007F2327456790  Unknown               Unknown  Unknown
libc.so.6          00007F2326EFE2F7  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327B899E8  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327C94E39  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327C94B32  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327B6E44A  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327B6DD5D  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327B6DBDC  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327B6DB0C  Unknown               Unknown  Unknown
libmpi.so.12       00007F2327B6F932  Unknown               Unknown  Unknown
libmpifort.so.12   00007F2328294B1C  Unknown               Unknown  Unknown
a.out              000000000040488B  Unknown               Unknown  Unknown
a.out              000000000040385E  Unknown               Unknown  Unknown
libc.so.6          00007F2326E4DD5D  Unknown               Unknown  Unknown
a.out              0000000000403769  Unknown               Unknown  Unknown
Where I am missing? what modifications I have to make to make it work?
