Intel® MPI Library
2292 Discussions
Static linkage MPI + OpenMP fails with multiple definition: hwloc_internal_memattr_set_value
NicolaPepe88
Hello!
I'm trying to link statically an MPI (or hybrid: MPI+OMP) application but the error is:
ld: /opt/intel/oneapi_2025.1.1/compiler/2025.1/lib/libiomp5.a(memattrs.o): in function `hwloc_internal_memattr_set_value': (.text+0x1a40): multiple definition of `hwloc_internal_memattr_set_value'; /opt/intel/oneapi_2025.1.1/mpi/2021.15/lib/libmpi.a(memattrs.o):/build/impi/_buildspace/release/src/hwloc/hwloc/../../../../../src/hwloc/hwloc/memattrs.c:938: first defined here
Same error for MPI or hybrid test.
As mentioned by @foxtran,`hwloc_internal_memattr_set_value` is used both in MPI and OpenMP runtimes.
I'm using the latest version of HPC toolkit : 2025.1.1 (30.04.2025)
Here the version of mpiifx
mpiifx -v
mpiifx for the Intel(R) MPI Library 2021.15 for Linux*
Copyright Intel Corporation.
ifx version 2025.1.1
Labels (2)
TobiasK
@NicolaPepe88 thanks for reporting that, The developers are looking into it
TobiasK
@NicolaPepe88
This issue will be fixed in the next release, oneAPI 2025.3 / Intel MPI 2021.17
