Intel® MPI Library
2285 Discussions
Try to Install Intel Cluster Studio 2016 on Centos 7 Skript isnt working
Kevin_F_1
Hi all,
I am trying to install an Intel-Cluster-Studio 2016 on my Centos7 installation. But the problem starts right on, when I am trying to execute the installation script.
install.sh: line 331: [: /tmp/intel.pset hostname.domain.name.bla binary operator expected
Is there a solution for this?
Thanks in advance
most sincerely
TheUnnamed
TimP
In case it's relevant:
If you wish to install under/for csh or tcsh, you should choose those versions of the install scripts.  The .sh scripts should support bash and sh shells.
Some other shells may not be supported, but a CentOS installation should include sh support, so you could try e.g. sudo /bin/sh ./install.sh
Then you might find that the customization of the compilervars scripts raises similar issues.
James_T_Intel
Following Tim's suggestion, what shell are you using?
James_T_Intel
What is the original package you downloaded?
Kevin_F_1
parallel_studio_xe_2016_update1
James_T_Intel
Kevin,
I apologize for not getting back to you sooner.  Look in your install.sh script at lines 322-337.  It should match this:
get_strings()
    strings_file="$user_tmp/intel.pset.strings.$USER.${HOSTNAME}"
    if [ -f "$pset_engine_cli_binary" ]; then
        "$pset_engine_cli_binary" --TEMP_FOLDER="$temp_folder" --log-disable --__get_string__=$strings_file $params
    else
        "$pset_engine_binary" --TEMP_FOLDER="$temp_folder" --log-disable --__get_string__=$strings_file $params 2>/dev/null
    fi
    exit_code=$?
    if [ -f $strings_file ] ; then
        . $strings_file
        rm $strings_file >/dev/null 2>&1
    else
        exit $exit_code;
    fi
Kevin_F_1
Hi, James, it seems identical.
get_strings()
    else
    fi
    exit_code=$?
        . $strings_file
    else
        exit $exit_code;
    fi
Kevin_F_1
Bump*
Is there now way to get this working? :(
Or should the system be functioning if I am only install the rpm with i.e. yum install?
James_T_Intel
If you install with RPMs, that should work.  Also, try the latest version.
