Intel® MPI Library
2288 Discussions
Unable to run mpi program with more than 1 core
Pavan9
The following is the stack when running with 2 cores. Running with 1 core the code is working.
The following are the env variables set
ONEAPI_ROOT=/opt/intel/oneapi
SETVARS_VARS_PATH=/opt/intel/oneapi/mpi/latest/env/vars.sh
I_MPI_FABRICS=shm
I_MPI_PERHOST=2
I_MPI_ROOT=/opt/intel/oneapi/mpi/2021.3.1
FI_PROVIDER_PATH=/opt/intel/oneapi/mpi/2021.3.1//libfabric/lib/prov:/usr/lib64/libfabric
PWD=/home/mpiuser
MANPATH=/opt/intel/oneapi/mpi/2021.3.1/man::
I_MPI_HYDRA_BOOTSTRAP_EXEC_EXTRA_ARGS=-o ConnectionAttempts=10
HOME=/root
I_MPI_HYDRA_HOST_FILE=/etc/mpi/hostfile
SETVARS_COMPLETED=1
TERM=xterm
SHLVL=1
I_MPI_PIN_ORDER=compact
CPATH=/opt/intel/oneapi/mpi/2021.3.1//include
_=/usr/bin/env
[0] MPI startup(): Run 'pmi_process_mapping' nodemap algorithm
[0] MPI startup(): Intel(R) MPI Library, Version 2021.3.1  Build 20210719 (id: 48425b416)
[0] MPI startup(): Copyright (C) 2003-2021 Intel Corporation.  All rights reserved.
[0] MPI startup(): library kind: release
impi_mbind_local(): mbind(p=0x7f497eef8000, size=1073741824) error=1 "Operation not permitted"
impi_mbind_local(): mbind(p=0x7f07374fd000, size=1073741824) error=1 "Operation not permitted"
Assertion failed in file ../../src/mpid/ch4/shm/posix/eager/include/intel_transport.c at line 354: absolute_l3_cache_id <= max
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(MPL_backtrace_show+0x1c) [0x7f844d5776dc]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(MPIR_Assert_fail+0x21) [0x7f844ce40171]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x48168d) [0x7f844cdbd68d]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x9da9a2) [0x7f844d3169a2]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x606b3b) [0x7f844cf42b3b]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x6f5a26) [0x7f844d031a26]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x1cb93c) [0x7f844cb0793c]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(PMPI_Init_thread+0xe0) [0x7f844cda6760]
/root/miniconda3/lib/python3.10/site-packages/mpi4py/MPI.cpython-310-x86_64-linux-gnu.so(+0x2fbc3) [0x7f844dd62bc3]
python(PyModule_ExecDef+0x70) [0x5976e0]
python() [0x598a69]
python() [0x4fdc1b]
python(_PyEval_EvalFrameDefault+0x5a6f) [0x4f443f]
python(_PyFunction_Vectorcall+0x6f) [0x4fe5ef]
python(_PyEval_EvalFrameDefault+0x4b4e) [0x4f351e]
python(_PyEval_EvalFrameDefault+0x731) [0x4ef101]
python(_PyEval_EvalFrameDefault+0x31f) [0x4eecef]
python() [0x4fddb4]
python(_PyObject_CallMethodIdObjArgs+0x137) [0x50c987]
python(PyImport_ImportModuleLevelObject+0x537) [0x50bcf7]
python() [0x517854]
python() [0x4fe1a7]
python(PyObject_Call+0x209) [0x50a8b9]
Abort(1) on node 0: Internal error
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(MPL_backtrace_show+0x1c) [0x7f38d72106dc]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(MPIR_Assert_fail+0x21) [0x7f38d6ad9171]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x48168d) [0x7f38d6a5668d]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x9da902) [0x7f38d6faf902]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x606b3b) [0x7f38d6bdbb3b]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x6f5a26) [0x7f38d6ccaa26]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(+0x1cb93c) [0x7f38d67a093c]
/opt/intel/oneapi/mpi/2021.3.1//lib/release/libmpi.so.12(PMPI_Init_thread+0xe0) [0x7f38d6a3f760]
/root/miniconda3/lib/python3.10/site-packages/mpi4py/MPI.cpython-310-x86_64-linux-gnu.so(+0x2fbc3) [0x7f38d79fbbc3]
python() [0x598a69]
python() [0x4fdc1b]
python() [0x4fddb4]
python() [0x517854]
python() [0x4fe1a7]
Abort(1) on node 1: Internal error
AishwaryaCV_Intel
Thank you for posting in intel community.
Could you please provide the following details so that we could check whether they are of supported type:
1. OS Details
2. CPU Details
Could you please check with I_MPI_FABRICS= ofi instead of 'shm' because it is used for single node.
NOTE: Could you please try to check with the latest version of Intel MPI(2021.10) and let us know if the issue persists , If so please provide us the sample producer and steps to reproduce at our end.
Thanks And Regards,
Aishwarya
AishwaryaCV_Intel
We haven't heard back from you, could you please provide details asked in previous response and let us know whether your issue is resolved or not with the latest version(2021.10)?. If yes, make sure to accept this as a solution.
Thank you and best regards,
Aishwarya
Pavan9
Sorry for the delay. The issue has been resolved. It was due to the architecture not supporting Intel MPI.
AishwaryaCV_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks And Regards,
Aishwarya
Juan_Colmenares
For anyone encountering this issue with an older version of IMPI, the suggestion above of setting I_MPI_FABRICS=ofi worked for me.
