Intel® MPI Library
Vasp run stop with impi
zhijian_f_
OS:Ubuntu 15.10 (intel xeon x5 2680 v3)
When I compile the VASP with impi 5,
and run "mpirun -n 24 /home/myname/work/vasp", the vasp stop, only show as follows:
 running on   24 total cores
 distrk:  each k-point on   24 cores,    1 groups
 distr:  one band on    6 cores,    4 groups
 using from now: INCAR
 vasp.5.3.5 31Mar14 (build Feb 06 2016 13:18:08) complex
 POSCAR found type information on POSCAR  N
 POSCAR found :  1 types and      54 ions
 scaLAPACK will be used
 LDA part: xc-table for Ceperly-Alder, standard interpolation
|           W    W    AA    RRRRR   N    N  II  N    N   GGGG   !!!           |
|           W    W   A  A   R    R  NN   N  II  NN   N  G    G  !!!           |
|           W    W  A    A  R    R  N N  N  II  N N  N  G       !!!           |
|           W WW W  AAAAAA  RRRRR   N  N N  II  N  N N  G  GGG   !            |
|           WW  WW  A    A  R   R   N   NN  II  N   NN  G    G                |
|           W    W  A    A  R    R  N    N  II  N    N   GGGG   !!!           |
|      VASP found    159 degrees of freedom                                   |
|      the temperature will equal 2*E(kin)/ (degrees of freedom)              |
|      this differs from previous releases, where T was 2*E(kin)/(3 NIONS).   |
|      The new definition is more consistent                                  |
 POSCAR, INCAR and KPOINTS ok, starting setup
 WARNING: small aliasing (wrap around) errors must be expected
 FFT: planning ...
 WAVECAR not read
but ./vasp (serial) is right, could you give me some advice?
Thanks!
zj fu
