Intel® MPI Library
Warning when sourcing the pcsevars.sh file
Paul_I_1
I get a warning when I source the file ...source /opt/intel/16.0/parallel_studio_xe_2016.0.047/psxevars.sh intel64
mpsvars.sh: Warning: Hardware events collection is disabled by default. To enable it, run mpsvars.sh with --vtune (recommended) or --papi option.
Why is this a warning?
James_T_Intel
This is related to the MPI Performance Snapshot tool.  The warning is to alert users that by default, there is no hardware event collection enabled in MPS, and you must explicitly enable it.
I'm going to move this to the correct forum.
Paul_I_1
The right way to do this is something like
/opt/intel/16.0/parallel_studio_xe_2016.0.047/psxevars.sh intel64 mps_hardware_events={yes|no}
Running the mpsvars.sh twice is not ideal.
James_T_Intel
I've put in a feature request to pass MPS options through to mpsvars.sh.
Andrew_R_2
I am running Ubuntu 16.04 LTS and I receive the following warning when I start the terminal:
What command should I run to correct this?
Andrew
James_T_Intel
As the warning message states, using mpsvars.sh --vtune or mpsvars.sh --papi.
James_T_Intel
The developers will not be implementing this.  In order to pass specific, non-default arguments to mpsvars.sh, you will need to call it directly.
