Intel® MPI Library
What's "classic"?
ryofurue2
A simple question:  What's the "classic" Fortran compiler?  The name implies that there are versions that are not "classic".
I downloaded and installed the Intel Fortran "classic" compiler (m_fortran-compiler-classic_p_2023.2.0.49001_offline.dmg ) on macOS.  But, somebody told me, why not use the OneAPI compiler?  It should be included in the HPC package.
Okay, then, I wiped out the installation (wiped out /opt/intel/ ), downloaded the HPC package (m_HPCKit_p_2023.2.0.49443.dmg ), and installed it.
But, this installer said that it was going to install the "classic" C++ compiler and "classic" Fortran compiler . . .
I'm just concerned: If "classic" is something that will be retired soon, it may not wise to start to use it now.
Xiaoping_D_Intel
The Intel® oneAPI product packages provide two Fortran compilers:
  • Intel® Fortran Compiler Classic (ifort) provides best-in-class Fortran language features, including full Fortran 2018 support, along with outstanding performance for Intel® Architecture CPUs.
  • The Intel® Fortran Compiler (ifx) has all of the Fortran language features of ifort, plus the added functionality of OpenMP* directives to offload to Intel GPUs. The OpenMP 5.0, 5.1 and 5.2 GPU offload features in ifx are not available in ifort.
More info can be found from:
Please note that macOS* is not supported for the ifx compiler.
Xiaoping_D_Intel
ryofurue2
Thank you!  That's all that I wanted to know.
