Intel® MPI Library
2284 Discussions
a cluster of two virtual machines cannot be created,it said cannot access "my another node name" using ssh command
James_B_16
I want to create a cluster of two virtual machines. I have followed the file "parallel_studio_xe_2015_update3/doc/Install_Guide.htm#prerequisites". However, when I get the  eighth step in Prerequisites,it occurs this situation:
Yes,cws02 is the master node ,cws01 is the other node.It requires me to input my current virtual machines's key word,but after i enter that ,it stayed there so long and never changed.I can't understand.
After that ,I command "./install_GUI.sh",and it goes smoothly until it get the  installation step,it tell me this:
Yes,it cannot access cws01 using SSH command .I guess it is because of the eighth step previous.
But I can access cws01 using ssh command in Centos terminal.Like this:
 Yes,at last of the picture,I can access it.So ,What happend?What can I do?Can you give me a more detailed installation file?
