Intel® MPI Library
error while loading shared libraries: libmpi_dbg.so.4: cannot restore segment prot aft
srinivasan_G_1
I have installed INTEL parallel studio XE cluster edition on our 10 Node cluster machine. I'm able to compile using mpiicc but when i try to run my code using mpirun i'm getting error like this
"error while loading shared libraries: /app/intelMPI//impi/4.1.3.048/intel64/lib/libmpi_dbg.so.4: cannot restore segment prot after reloc: Permission denied"
I have checked my environment varibles path in .bashrc file, i've properly declared the LD_LIBRARY_PATH in .bashrc file. i dont know exactly what is happening.
Artem_R_Intel1
Hi Srinivasan,
Could you please check SELinux status on your system? If it's enabled try to disable it or configure SELinux to allow libmpi_dbg.so.4 execution.
Artem_R_Intel1
Hi Srinivasan,
srinivasan_G_1
Thanks artem,
SELINUX was enabled. I disabled selinux, its now working.
