Intel® MPI Library
2275 Discussions
failed generate trace file with mpirun
Zhoulong_J_Intel
My application is a python program and mpi is called as mpi4py(built with intel mpi), and it needs to be killed during the runing(it needs a long time, we only profile a little). I use LD_PRELOAD=libVTfs.so mpirun -trace -n 2 python My application, it didn't generate stf as doc said. It only generate a file folder which contains stat-0.bin and stat-1.bin(filesize=0), any wrong with my configure? I already source mpivars.sh, itacvars. Thanks very much!
James_S
Hi Zhoulong,
Crashing applications or long running applications which are stopped by the user (e.g. check-pointed) do not produce an Intel® Trace Analyzer and Collector tracefile. Here are some ways to generate the trace file, can you please try:
1. By preloading the failsafe library:   mpirun –genv LD_PRELOAD libVTfs.so ...
    alternative:  export LD_PRELOAD=libVTfs.so
                       mpirun ...
2. By static linkage with libVTfs.so
3. The VT_CONFIG variable "DEADLOCK-TIMEOUT 10s" also works: if deadlock, interrupt and write a tracefile
Zhuowei
James_S
Hi Zhoulong,
                       mpirun ...
Zhuowei
Zhoulong_J_Intel
thanks, it worked
