Intel® MPI Library
2299 Discussions
ifortvars.bat in oneAPI HPC tool kit
arogz
Hello! I am trying to link ABAQUS to Fortran compiler to run subroutines... I installed oneAPI HPC tool kit but I cannot find the file ifortvars.bat that previous versions of Parallel Studio had (e.g. “C:\ProgramFiles(x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\bin\ifortvars.bat”) is there an equivalent file in this new software distribution?
In the attached image is a caption of the folders I see under Intel>OneAPI folder
I would appreciate your insights on this matter.
JohnNichols
Honored Contributor I
use fileseek
look setvars.bat
AbhishekD_Intel
If you are looking only for sourcing the compiler environment the running "C:\Program Files (x86)\Intel\oneAPI\compiler\2021.1.1\env\vars.bat" intel64 it will source all of the compiler installed and you will get the ifort to use.
You can also try running "C:\Program Files (x86)\Intel\oneAPI\setvars.bat" it will also work.
Warm Regards,
Abhishek
AbhishekD_Intel
As requested we are closing this thread. Post a new thread if you have any other issues.
Warm Regards,
Abhishek
