Intel® MPI Library
2286 Discussions
No route to host, Network is unreachable
lmh
I recently made my own cluster server and tried to use intel mpi.. and had some troubles.
My cluster server has 8 nodes and each with intel-i9(Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz) connected via wired hub.
To check if it’s working, I wrote the following code:
//hello_mpi.c
#include <mpi.h>
#include <stdio.h>
int main(int argc, char** argv)
          MPI_Init(NULL,NULL);
          int world_size;
          MPI_Comm_size(MPI_COMM_WORLD, &world_size);
          int world_rank;
          MPI_Comm_rank(MPI_COMM_WORLD, &world_rank);
          char processor_name[MPI_MAX_PROCESSOR_NAME];
          int name_len;
          MPI_Get_processor_name(processor_name, &name_len);
          printf("Hello world from processor %s, rank %d out of %d processors\n", processor_name, world_rank, world_size);
          MPI_Finalize();
and I compile the code with this command:
mpiicc ./hello_mpi.c -o hello_mpi
and it works.
When I run this code with this command:
mpirun ./hello_mpi
It prints out the results:
Hello world from processor node0, rank 2 out of 10 processors
Hello world from processor node0, rank 7 out of 10 processors
Hello world from processor node0, rank 1 out of 10 processors
Hello world from processor node0, rank 3 out of 10 processors
Hello world from processor node0, rank 4 out of 10 processors
Hello world from processor node0, rank 5 out of 10 processors
Hello world from processor node0, rank 9 out of 10 processors
Hello world from processor node0, rank 6 out of 10 processors
Hello world from processor node0, rank 8 out of 10 processors
Hello world from processor node0, rank 0 out of 10 processors
But, when I try to check the same code using multi- nodes with this command:
mpirun -host node0,node1,node2,node3,node4,node5,node6,node7  ./hello_mpi
It prints out an error message:
Hello world from processor node0, rank 2 out of 80 processors
Other MPI error, error stack:
PMPI_Finalize(214)...............: MPI_Finalize failed
PMPI_Finalize(159)...............:
MPID_Finalize(1280)..............:
MPIDI_OFI_mpi_finalize_hook(1807):
MPIR_Reduce_intra_binomial(142)..:
MPIC_Send(131)...................:
MPID_Send(771)...................:
MPIDI_send_unsafe(220)...........:
MPIDI_OFI_send_normal(398).......:
MPIDI_OFI_send_handler_vci(647)..: OFI tagged send failed (ofi_impl.h:647:MPIDI_OFI_send_handler_vci:No route to host)
Hello world from processor node5, rank 59 out of 80 processors
Abort(810115343) on node 10 (rank 10 in comm 0): Fatal error in PMPI_Finalize: Other MPI error, error stack:
MPIDI_OFI_send_handler_vci(647)..: OFI tagged send failed (ofi_impl.h:647:MPIDI_OFI_send_handler_vci:Network is unreachable)
Hello world from processor node5, rank 56 out of 80 processors
Abort(810115343) on node 30 (rank 30 in comm 0): Fatal error in PMPI_Finalize: Other MPI error, error stack:
Abort(810115343) on node 50 (rank 50 in comm 0): Fatal error in PMPI_Finalize: Other MPI error, error stack:
Strangely, when I run the code with just node3 and node4, it works!(without any error message).
I wonder if anyone has any insight into what the problem might be?
Thank you very much for your help.
AbhishekD_Intel
We can see that there are two same threads from you in this forum. So will no longer monitor this thread. Please expect a reply from the other thread. Follow the below link for more details.
https://community.intel.com/t5/Intel-oneAPI-HPC-Toolkit/mpi-machine-file-and-host-command-do-not-work-No-route-to-host/m-p/1245879#M7623
We will look into the issue and will get back to you as soon as possible.
Warm Regards,
Abhishek
lmh
The link that you mention is the thread that I wrote before. Because I worry about the mis-understanding, I wrote this thread again with some progress..
