Intel® MPI Library
2288 Discussions
intel mpi 2019 - I_MPI_PROCESS_MANAGER I_MPI_SHM_LMT mpiexec.hydra replacement
psing51
I am using intel mpi 2019 to run few applications.
i get following warning messages during start of the run -
[0] MPI startup(): I_MPI_PROCESS_MANAGER environment variable is not supported.
[0] MPI startup(): I_MPI_SHM_LMT environment variable is not supported.
[0] MPI startup(): Similar variables:
I_MPI_SHM_OPT
A)
Is there a way to supress these unsupported  environment variables messages?
B)
What would be the replacement of these 2 outdated variables ?.
Currently i am using -
I_MPI_PROCESS_MANAGER = hydra
I_MPI_SHM_LMT = shm
is the following equivalent  -
unset  I_MPI_PROCESS_MANAGER
unset I_MPI_SHM_LMT
I_MPI_SHM_OPT = shm
I plan to set these up in shell scripts ( before mpirun) as i dont have permissions to remove these variables from the main module file.
c)
Also, can i replace
mpiexec.hydra with mpirun ?
- puneet
SantoshY_Intel
Could you please provide us with the version of Intel MPI 2019 & Operating System you are using?
Thanks & Regards,
Santosh
psing51
OS: SUSE Linux Enterprise Server 15 SP3
intel mpi - Intel(R) MPI Library for Linux* OS, Version 2019 Update 4 Build 20190430 (id: cbdd16069)
SantoshY_Intel
we no longer support MPI 2019 versions except MPI 2019 update 9(2020 update 4). please upgrade to any one of the supported versions mentioned in the link below:
https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-parallel-studio-xe-su...
Thanks & Regards,
Santosh
SantoshY_Intel
We are closing this issue. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Santosh
