Intel® MPI Library
libimf.so not found
mevel
Ubuntu 18.04
in a terminal, ifort myprog.f90 works and a.out is generated.
As I use Code:Block ( IDE) , I get the message libimf.so not found??
I can't figure out this
mevel
Hi, my problem is fixed.
In a previous version of Code:Block, the program was not sensible to special characters. With version 1.7  of Code:Blocks and Intel OneApi, it was not any more the case.
After removing Téléchargement  , and creating Telechargement without the character "é"  , It works. That is great, only a dummy character!!
mevel
I can add, that with c:B, I have no executable : le compiler works but not linkage
SantoshY_Intel
>>"in a terminal, ifort myprog.f90 works and a.out is generated."
Are you able to run ./a.out in the terminal?
>>"As I use Code:Block ( IDE) , I get the message libimf.so not found??"
Can you provide the steps to reproduce the issue(Commands)?
Thanks & Regards,
Santosh
mevel
SantoshY_Intel
Glad to know that your issue has been resolved. We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards
Santosh
