Intel® MPI Library
2273 Discussions
mp_linpack / mpi_exec dapl_cma_active: ARP_ERR, retries(15) ...
pmonday
I've read through a couple of other threads with a similar issue but I think I'm not quite able to get this thing running. It could be that I have several IB interfaces and I didn't see an option for specifying which to use.
In a nutshell, I've compiled and am trying to run Intel's MP_LINPACK.
The run starts, and exits with the retries exhausted (as shown here):
This run was done on: Thu May 19 14:18:55 MDT 2011
[1] MPI startup(): RDMA data transfer mode
[0] MPI startup(): RDMA data transfer mode
[3] MPI startup(): RDMA data transfer mode
[2] MPI startup(): RDMA data transfer mode
[0] MPI startup(): DAPL provider OpenIB-cma
[0] MPI startup(): dapl data transfer mode
[1] MPI startup(): DAPL provider OpenIB-cma
[1] MPI startup(): dapl data transfer mode
[2] MPI startup(): DAPL provider OpenIB-cma
[2] MPI startup(): dapl data transfer mode
[3] MPI startup(): DAPL provider OpenIB-cma
[3] MPI startup(): dapl data transfer mode
[0] MPI startup(): static connections storm algo
pg-v2:11063: dapl_cma_active: ARP_ERR, retries(15) exhausted -> DST 10.155.90.13,4866
pg-v2:11063: dapl_cma_active: ARP_ERR, retries(15) exhausted -> DST 10.155.90.12,4755
[0:pg73-v2] unexpected DAPL event 0x4008
Assertion failed in file ../../dapl_module_init.c at line 4226: 0
internal ABORT - process 0
rank 0 in job 8 pg73-v2_55194 caused collective abort of all ranks
exit status of rank 0: return code 1
Done: Thu May 19 14:19:56 MDT 2011
This would tell me, I believe, that I cannot reach the other nodes. I have the following environment variables:
I_MPI_DEBUG=5
I_MPI_DEVICE=rdma:OpenIB-cma
I_MPI_FABRICS_LIST=ofa,dapl
I_MPI_MPD_RSH=ssh
I_MPI_ROOT=/opt/intel/impi/4.0.1.007
I'm actually trying to use ib3 rather than ib0, ib0 is down at the moment, so I wonder if that has something to do with the issue?
Here is the ibstat info relative to the ib3 port:
CA 'mlx4_3'
CA type: MT26428
Number of ports: 1
Firmware version: 2.8.600
Hardware version: a0
Node GUID: 0x0002c903000bb0dc
System image GUID: 0x0002c903000bb0df
Port 1:
State: Active
Physical state: LinkUp
Rate: 40
Base lid: 24
LMC: 0
SM lid: 2
Capability mask: 0x02510868
Port GUID: 0x0002c903000bb0dd
Link layer: IB
I'm at MLNX_OFED_LINUX-1.5.2-2.1.0 (OFED-1.5.2-20101219-1546):
I'm using, basically, the default runme_intel64 script with a couple of minor changes
#!/bin/bash
echo "This is a SAMPLE run script. Change it to reflect the correct number"
echo "of CPUs/threads, number of nodes, MPI processes per node, etc.."
# You can find description of all Intel MPI parameters in the
# Intel MPI Reference Manual.
# See /doc/Reference_manual.pdf
export I_MPI_EAGER_THRESHOLD=128000
# This setting may give 1-2% of performance increase over the
# default value of 262000 for large problems and high number of cores
export OUT=xhpl_intel64_outputs.txt
date
cp HPL_serial.dat HPL.dat
echo -n "This run was done on: "
date
# Capture some meaningful data for future reference:
echo -n "This run was done on: " >> $OUT
date >> $OUT
echo "HPL.dat: " >> $OUT
cat HPL.dat >> $OUT
echo "Binary name: " >> $OUT
ls -l xhpl_intel64 >> $OUT
echo "This script: " >> $OUT
cat runme_intel64 >> $OUT
echo "Environment variables: " >> $OUT
env >> $OUT
echo "Actual run: " >> $OUT
# Environment variables can also be set on the Intel MPI command
# line using the -genv option:
# mpiexec -np 4 ./xhpl_intel64 | tee -a xhpl_intel64_outputs.txt
# In case of multiple nodes involved, please set the number of MPI processes
# per node (ppn=1,2 typically) through the -perhost option (because the
# default is all cores):
mpiexec -perhost 1 -np 4 /mnt/shared/apps/mp_linpack/xhpl_intel64
echo -n "Done: " >> $OUT
date >> $OUT
echo -n "Done: "
date
Any thoughts? I've regularly run MPI programs on the cluster with openmpi-1.4.2 but things are usually a little different. I tend not to use my head node as one of the compute nodes, this Intel library seems to like to use it as rank 0 :( That's a minor thing though, I suspect there is a way around it.
Any clues on the above and why I couldn't connect? Are there environment variables to indicate the ibx card to use?
Paul Monday
pmonday
Just a quick follow-up, I am able to run across most of my nodes at this point, except for those that have cards other than ib0 as their primary interface. If this is, in fact, a simple problem of mpiexec and mpd defaulting to want to run on ib0, is there an easy way to tell it on several nodes to use a different ib?
Paul
Dmitry_K_Intel2
Hi Paul,
You probably need to use a command like:
mpiexec n #p1 host node1 exe1 : n #p2 host node2 exe2 : n #p3 host node3 exe3
I've tried:
mpiexec -genv I_MPI_FABRICS dapl -n 1 -host pg73_v2 -env I_MPI_DAPL_PROVIDER ib0-v1 ./hello : -n 1 -host pg74_v2 -env I_MPI_DAPL_PROVIDER ib1-v1 ./hello
I cannot guarantee that it will work on your cluster. Please check providers names in /etc/dat.conf
Regards!
Dmitry
pmonday
Thanks, I will give this a try!
