Intel® MPI Library
mpi failed using Intel sample code
ramy_a_
I have installed intel parallel studio xe cluster edition 2016  on HPC environment.
All compilers are working fine.
when I tried to execute the following commands:
#mpirun hostname
#mpirun  --machinfile hosts  hostname
It executed successfully returning all nodes' hostname
And I compiled the following sample <Intel_DIR>/compilers_and_libraries/linux/samples/en/mpi/test.c
using the following:
#mpiicc test.c
and execute the following command:
#mpirun a.out
#mpirun --machinfile hosts a.out
but I got the following error:
HYDU_create_process (../../utils/launch/launch.c:622): execvp error on file a.out (No such file or directory)
I wonder what might cause this error
Appreciate  your help.
Artem_R_Intel1
Could you please make sure that a.out is available on all the nodes from the hostfile? Also try to run the following variations of your initial command:
mpirun --machinfile hosts ./a.out
mpirun --machinfile hosts <full_path>/a.out
Artem_R_Intel1
ramy_a_
Thanks Artem.
That solved my problem
kelly__shane
Thanks! Using the full path is what solved my similar error.
