Intel® MPI Library
2293 Discussions
[mpiexec@HOST0004] validate_fn (..\windows\src\mpiexec_params_init_win.c:290): server rejecte
Randykos
What could be causing the following issue when running "mpiexec.exe -validate -host localhost"
[mpiexec@HOST0004] validate_fn (..\windows\src\mpiexec_params_init_win.c:290): server rejected credentials on host localhost
ref: IMPI version, hydra registered, credentials cached, I even tried "
C:\>klist purge"
C:\>
"%I_MPI_ONEAPI_ROOT%\env\vars.bat" has no output (blank line)
C:\>"%I_MPI_ONEAPI_ROOT%\bin\mpiexec" -version
Intel(R) MPI Library for Windows* OS, Version 2021.5 Build 20211102Copyright 2003-2021, Intel Corporation.
C:\>"C:\Program Files (x86)\Intel\oneAPI\mpi\2021.5.1\bin\hydra_service.exe" -installIntel(R) MPI Library Hydra Process Manager 2021.5 installed.
C:\>"C:\Program Files (x86)\Intel\oneAPI\mpi\2021.5.1\bin\hydra_service.exe" -startIntel(R) MPI Library Hydra Process Manager 2021.5 started.
C:\>"C:\Program Files (x86)\Intel\oneAPI\mpi\2021.5.1\bin\mpiexec.exe" -registeraccount (domain\user) [XXX\user]:password:confirm password:credentials were saved.
C:\>"C:\Program Files (x86)\Intel\oneAPI\mpi\2021.5.1\bin\mpiexec.exe" -validate -host localhost[mpiexec@HOST0004] validate_fn (..\windows\src\mpiexec_params_init_win.c:290): server rejected credentials on host localhost
SharonT
Looks like the problem was resolved after I added the user account to "Remote Management Users" group under Computer Management -> Local Users And Groups
Thanks for the support
SantoshY_Intel
We tried at our end using Intel MPI Library 2021.5.0 on a windows machine using the below steps and it worked fine.
  1. Use the following commands to determine the user names and domain names of your machine.
    > whoami
    domain-name\user-name
  2. Next, invoke the following commands to set up the Hydra process manager:
    > hydra_service -start
    > mpiexec -register
      password
      confirm password
    > mpiexec -validate
      SUCCESS
    Note: Please make sure to give "account (domain\user)" name for mpiexec -register as "domain-name\user-name" which is the output of "whoami" from step 1.
For more information regarding the steps, please refer to the link:
https://www.intel.com/content/www/us/en/developer/articles/training/micro-cluster-setup-with-intel-mpi-a-stepwise-guide-to-setting-up-the-smallest-windows.html
Please try the above steps and let us know if it works. If this resolves your issue, make sure to accept this as a solution. This would help others with a similar issue. Thank you!
Santosh
SantoshY_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Santosh
Randykos
Hi Santos,
Thank you for reaching for a status - your commands were the same as we had done prior.
hydra_service  -install
mpiexec -remove
mpiexec -register
mpiexec -validate
Validate still fails with the same:
validate_fn (..\windows\src\mpiexec_params_init_win.c:290): server rejected credentials on host Hostname
ex:
SantoshY_Intel
Could you please provide your environment details( CPU & its version)?
Thanks & Regards,
Santosh
SharonT
We have several different Windows machines.
Below is the processor details for some.
SantoshY_Intel
>>" validate_fn (..\windows\src\mpiexec_params_init_win.c:290): server rejected credentials on host <hostname>"
We will get the above error only if we give the wrong credentials. Please follow the below steps for 'mpiexec -validate':
  1. The value of 'domain-name\user-name' must be the same as the output of 'whoami' command.
  2. The password must be the one with which you log in to your machine.
If you still face the issue, then try to skip the command 'mpiexec -validate' and try to run a sample MPI application. While running an MPI program, If it prompts you to give a username & password, then give it a try and let us know if you can able to run a sample MPI program.
Also, could you please check whether you are using a supported windows target machine by referring to the below Intel MPI system requirements page?
URL: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/mpi-library-system-requirements.html
If you are not using a supported target operating system, then we recommend you use any one of the supported target OS and try again.
Thanks & Regards,
Santosh
SharonT
I'm using Windows Server 2019 which is supported.
When I'm registering my regular account the validation fails.
When I'm registering my admin (elevated) account then validation is successful.
This is regardless of how I logged into the machine and the "whoami" command output.
Seems like it has something to do with permissions.
SharonT
I'm running mpiexec -n 2 -ppn 1 -hosts <hostnames> hostname for testing and it fails after I register my regular account
SharonT
SantoshY_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. Can we go ahead and close this issue?
Thanks & Regards,
Santosh
Randykos
Thank you Santos and Sharon!
Yes, please close.
SantoshY_Intel
Thanks for the confirmation.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
