Intel® MPI Library
2272 Discussions
mpiexec hangs with localonly on Windows when smpd service not installed
Ben_Held
I'm interested as to why mpiexec hangs if I have the Intel MPI RTE installed, but not the service installed (you can get here by installing the RTE and then running smpd -uninstall).
A verbose runs shows this:
mpiexec np 2 localonly notepad verbose
...\\smpd_get_full_path_name
....fixing up exe name: 'notepad' -> '(null)'
.../smpd_get_full_path_name
...handling executable:
notepad.exe
...\\smpd_get_next_host
....\\smpd_get_host_id
..../smpd_get_host_id
.../smpd_get_next_host
...\\smpd_create_cliques
....\\prev_launch_node
..../prev_launch_node
.../smpd_create_cliques
...\\smpd_fix_up_host_tree
.../smpd_fix_up_host_tree
../mp_parse_command_args
..host tree:
.. host: localhost, parent: 0, id: 1
..launch nodes:
.. iproc: 1, id: 1, exe: notepad.exe
.. iproc: 0, id: 1, exe: notepad.exe
..\\SMPDU_Sock_create_set
...\\smpd_get_smpd_data
....\\smpd_get_smpd_data_from_environment
..../smpd_get_smpd_data_from_environment
....\\smpd_get_smpd_data_default
..../smpd_get_smpd_data_default
...\\smpd_create_context
....\\smpd_init_context
.....\\smpd_init_command
...../smpd_init_command
..../smpd_init_context
.../smpd_create_context
....Unable to get the data for the key 'binary'
...\\smpd_start_win_mgr
....starting command:1: "C:\\ProjectsSVN\\ORION_WC\\src\\x64\\Release\\mpiexec.exe" -d 19 -mgr -pipe smpd_temporary_pipe -local
....CreateProcess
James_T_Intel
Hi Ben,
Why are you running with SMPD uninstalled?
Sincerely,
James Tullos
Technical Consulting Engineer
Intel Cluster Tools
Ben_Held
Reasonable question - it's a scenario that we are concerned our customers might encounter. That's all. It would be nice if didn't hang...
James_T_Intel
Hi Ben,
Generally, this is an unsupported scenario. Without SMPD, the processes would have no means of performing MPI communications.
Sincerely,
James Tullos
Intel Cluster Tools
Ben_Held
I understand this, but it would be far better if mpiexec would fail in this case. Is this something I can request from Intel?
James_T_Intel
Hi Ben,
I can certainly put in a feature request for this. Let me make sure I've got a good understanding of what you want first. Basically, if mpiexec is run in a scenario where SMPD is not running, it should fail (preferably with an informative error message) rather than attempting to proceed. Is this correct?
Sincerely,
James Tullos
Intel Cluster Tools
Ben_Held
Correct. The specific case is where the Intel MPI RTE is installed, but for whatever reason the smpd service is NOT running.
James_T_Intel
Hi Ben,
Ok, I'm putting in the request. Also, this behavior also occurs on the full SDK, not just the RTE.
Sincerely,
James Tullos
Intel Cluster Tools
