Intel® MPI Library
2275 Discussions
mpiexec is ignoring the no. of processes after each hostname in the hostfile
YaDev
Running MPI using a hostfile like this
mpiexec -f hostfile executable
The hostfile has the content, for example
host1:4
host2:2
but MPI just runs the maximum number of processes on each host. It just completely ignore the process numbers in the hostfile??
YaDev
Understandable that this is low priority. It is just a suggestion but thanks!
TobiasK
@YaDev
You are using the hostfile option while you need the machine file option. A hostfile does not contain the number of slots available, only the machinefile contains this information.
https://www.intel.com/content/www/us/en/developer/articles/technical/controlling-process-placement-with-the-intel-mpi-library.html
mpirun -machinefile hostfile executable
YaDev
Oh ok thank you!
YaDev
Hello again,
Would Intel not consider instead of having this -machinefile flag, just merge it into the hostfile under the -f flag just like what MPICH is doing? There is no reason to have this separate -machinefile flag, right?
With just the -f hostfile to list
Example 1)
host1
host2
host3
Example 2)
host1:3
host2
host3:5
The -machinefile is just quite redundant IMHO.
TobiasK
I was not aware that machinefile and hostfile are the same for MPICH, however, other implementations also have this differentiation. I will bring you feedback to the developers but I do not expect that we change the behavior due to backwards combability issues.
YaDev
