I'm trying to run an MPI code compiled with mpiifort. At the begenning of the code, while trying to open and read an ASCII file (the file is read by all processors)
file_name = 'Donnees_Simulation.dat' Open(11,File = file_name) Read(11,*);Read(11,*)
Unfortunately, I received this error where line 79 corresponds to the first Read applied to the imput file :
mkdir ${tmpdir};cd ${tmpdir}
+ mkdir /san/home/fenni/tmp.748461
+ cd /san/home/fenni/tmp.748461
mpirun "${LOADL_STEP_INITDIR}"/myprog
+ mpirun '/san/work/fenni/Mycode/CodeFortranMPI/myprog'
forrtl: severe (24): end-of-file during read, unit 11, file /san/home/fenni/tmp.748461/Donnees_Simulation.dat
Image PC Routine Line Source
myprog 0000000000FD722A Unknown Unknown Unknown
myprog 0000000000FD5D26 Unknown Unknown Unknown
myprog 0000000000F859F0 Unknown Unknown Unknown
myprog 0000000000F53D3E Unknown Unknown Unknown
myprog 0000000000F5327F Unknown Unknown Unknown
myprog 0000000000F68DFE Unknown Unknown Unknown
myprog 0000000000435A7C scene_simulation_ 79 Scene_Simulation.f90
myprog 00000000004138D0 Unknown Unknown Unknown
myprog 000000000041336C Unknown Unknown Unknown
libc.so.6 00002B05B992AC36 Unknown Unknown Unknown
myprog 0000000000413269 Unknown Unknown Unknown
libc.so.6 00002B15E666BC36 Unknown Unknown Unknown
rank 2 in job 1 n128_57493 caused collective abort of all ranks
exit status of rank 2: return code 24
rank 1 in job 1 n128_57493 caused collective abort of all ranks
exit status of rank 1: return code 24
rm -rf ${tmpdir}
+ rm -rf /san/home/fenni/tmp.748461
I find this, a little bizarre, since the same code run correctly on Windows with the intel compiler Composer XE 2013 and MPICH2 with the simple multi-purpose Daemon (SMPD) environment.
Can any one help please, Do this error has any relation with the compiler, did I miss any additionnal option ?
Hi Ines,
I am unable to reproduce this behavior. What Linux* distribution and filesystem are you using? What version of the Intel® MPI Library and what compiler are you using?
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
