Intel® MPI Library
mpirun init fatal error for hello world example
Lion__Konstantin
I'm running into a fatal error when trying to run the simple Hello world test with mpirun -np 2 and above. It works fine when using only one process. See the output below. Do you have an idea what the problem is?
lion@sol48: ~/FHI-aims/09_06_20/testcases/H2O-relaxation $ mpiifort -v
mpiifort for the Intel(R) MPI Library 2019 for Linux*
Copyright 2003-2018, Intel Corporation.
ifort version 19.0.0.117
lion@sol48: ~/FHI-aims/09_06_20/testcases/H2O-relaxation $ cat test.f90
! Copyright 2003-2018 Intel Corporation.
! This software and the related documents are Intel copyrighted materials, and
! your use of them is governed by the express license under which they were
! provided to you (License). Unless the License provides otherwise, you may
! not use, modify, copy, publish, distribute, disclose or transmit this
! software or the related documents without Intel's prior written permission.
! This software and the related documents are provided as is, with no express
! or implied warranties, other than those that are expressly stated in the
! License.
        program main
        use mpi
        implicit none
        integer i, size, rank, namelen, ierr
        character (len=MPI_MAX_PROCESSOR_NAME) :: name
        integer stat(MPI_STATUS_SIZE)
        call MPI_INIT (ierr)
        call MPI_COMM_SIZE (MPI_COMM_WORLD, size, ierr)
        call MPI_COMM_RANK (MPI_COMM_WORLD, rank, ierr)
        call MPI_GET_PROCESSOR_NAME (name, namelen, ierr)
        if (rank.eq.0) then
            print *, 'Hello world: rank ', rank, ' of ', size, ' running on ', name
            do i = 1, size - 1
                call MPI_RECV (rank, 1, MPI_INTEGER, i, 1, MPI_COMM_WORLD, stat, ierr)
                call MPI_RECV (size, 1, MPI_INTEGER, i, 1, MPI_COMM_WORLD, stat, ierr)
                call MPI_RECV (namelen, 1, MPI_INTEGER, i, 1, MPI_COMM_WORLD, stat, ierr)
                name = ''
                call MPI_RECV (name, namelen, MPI_CHARACTER, i, 1, MPI_COMM_WORLD, stat, ierr)
            enddo
        else
            call MPI_SEND (rank, 1, MPI_INTEGER, 0, 1, MPI_COMM_WORLD, ierr)
            call MPI_SEND (size, 1, MPI_INTEGER, 0, 1, MPI_COMM_WORLD, ierr)
            call MPI_SEND (namelen, 1, MPI_INTEGER, 0, 1, MPI_COMM_WORLD, ierr)
            call MPI_SEND (name, namelen, MPI_CHARACTER, 0, 1, MPI_COMM_WORLD, ierr)
        endif
        call MPI_FINALIZE (ierr)
        end
lion@sol48: ~/FHI-aims/09_06_20/testcases/H2O-relaxation $ mpiifort test.f90
lion@sol48: ~/FHI-aims/09_06_20/testcases/H2O-relaxation $ mpirun -np 1 ./a.out
 Hello world: rank            0  of            1  running on
 sol48
lion@sol48: ~/FHI-aims/09_06_20/testcases/H2O-relaxation $ mpirun -np 2 ./a.out
Abort(1093903) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(607)..........:
MPID_Init(731).................:
MPIR_NODEMAP_build_nodemap(710): PMI_KVS_Get returned 4
In: PMI_Abort(1093903, Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_NODEMAP_build_nodemap(710): PMI_KVS_Get returned 4)
Abort(1093903) on node 1 (rank 1 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
GouthamK_Intel
Hi Konstantin,
Thanks for reaching out to us!
We tried to reproduce the error which you are facing but we are unable to reproduce it.
We got the following when we ran the code.
u30009@s001-n179:~/goutham/forums/856899_mpirun_initfatal/test$ mpirun -np 1 ./a.out
 s001-n179
u30009@s001-n179:~/goutham/forums/856899_mpirun_initfatal/test$ mpirun -np 2 ./a.out
 Hello world: rank            0  of            2  running on
 s001-n179
 Hello world: rank            1  of            2  running on
 s001-n179
Please refer to the below thread which discusses issue similar to your issue:
https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/799716
Please let us know if the above link helps you.
Thanks & Regards
Goutham
jimdempseyatthecove
PMI_KVS_Get failure 4:
See:
https://github.com/hpcng/singularity/issues/5118
locate: mmiesch commented on Mar 16
Jim Dempsey
GouthamK_Intel
Hi Konstantin,
Could you please let us know the status of the issue you are facing.
If the issue still persists, please provide the output of the below check.
  1. Please verify if you are able to access the nodes which are present in the node file. Depending on your environment(Job Scheduler) nodefile may vary.
Example:
In our environment: mpirun uses $PBS_NODEFILE as a machine file.
You may check your appropriate nodefile depending on your environment in below link:
https://software.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/running-applications/job-schedulers-support.html
 2. Run the Intel® Cluster Checker:
•    source clckvars.sh
•    clck -f <nodefile>
Please check the below link for more details.
https://software.intel.com/content/www/us/en/develop/documentation/cluster-checker-user-guide/top/getting-started.html
Thanks & Regards
Goutham
GouthamK_Intel
Hi Konstantin,
Could you please let us know the status of the issue you are facing?
If your issue still persists, please do let us know. So that we will be able to help you resolve your issue.
if your issue is resolved, let us know whether we can close this thread.
Thanks & Regards
Goutham
GouthamK_Intel
Hi Konstantin,
Goutham
GouthamK_Intel
We have not heard back from you so we are closing this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards
Goutham
