Intel® MPI Library
mpitune_fast tuning file
Matthew_Grismer
I've run mpitune_fast on our cluster for each of the available benchmarks, and an MPI tuning file was produced for each.  But, it seems like I need to combine them into one file in order to use them  with MPI.  The alternative appears to be to run mpitune_fast for all the benchmarks in one command, but when I tried this it was taking too long for the queues on the system.  Is there a way to combine the individual benchmark tuning files into on tuning file for all the benchmarks?
Mahan
Hi Matthew,
In that case you can us the following to merge many tuning files to create a master tuning .dat file
I_MPI_TUNING_BIN=tuned1.dat,tuned2.dat  \
I_MPI_TUNING_BIN_DUMP=./tuned_merged.dat mpirun -n 1 ./dummy_mpi_app
​Here, the dummy_mpi_app could be any dummy mpi executable
Please let me know if this is what you are looking for.
Mahan
Hi Matthew,
If you are using mpitune_fast, then it will able to create a merged file for all the mpi applications that you need. This can be done in the following manner, here I am doing it for four mpi functions
mpitune_fast -f ./hostfile -c allreduce,bcast,barrier,reduce
After the run finishes a folder named "tuning_results" will be created which will contain the merged .dat file
Please let me know does this answer your question.
Matthew_Grismer
Unfortunately I cannot run all the applications in one invocation of mpitune_fast (at the scale that I want) because it takes too long for the queues on the machine, i.e. it takes 2 days for the allreduce application alone to run.  So, I ran them all separately, but now have separate .dat files that I would like to merge into one.
Mahan
Hi Matthew,
