Intel® MPI Library
2284 Discussions
ld: libtest.so: undefined reference to `mpi_f08_compile_constants_MP_mpi_logical_'
DataScientist
Valued Contributor I
I can successfully compile an MPI Fortran shared library with CMake using Intel ifort and ifx. However, I persistently get the following error when linking other binary files with the shared library:
Basically non of MPI library symbols are recognized by the linker. How is that possible?
Barbara_P_Intel
Moving this to the HPC Toolkit Forum. The support team over there understand MPI much better.
TobiasK
DataScientist
Thank you @TobiasK . I suppose it should, but I already reverted all mpi_f08 syntax to mpi F90 syntax because of deadlines.
TobiasK
@DataScientist I would highly recommend to switch to MPI_F08, the mpi module will not get the newest features and is somewhat declared deprecated by the standard. Considering the fast moving MPI standard, it will take a while though until you notice a difference.
