Intel® MPI Library
2285 Discussions
mpitune get "could not dump the session, because unknown encoding: utf-8"
Xinwei_X_Intel
Hi forum,
I try the following command on a server: (impi 5.0.2.044, icc 2015.2.164)
mpitune -of analysis.conf -application \"mpirun -n 24 -host `hostname` ./myexe\"
It did run for a while but output nothing of analysis.conf. Meanwhile the console output message like:
ERR | Could not dump the session, because unknown encoding: utf-8
I try to change LANG=C, as locale outputs:
LANG=C
LC_CTYPE="C"
...(all other environment variables are "C")
How can I run successfully of mpitune to get analysis.conf which has real contents. Thanks!
Artem_R_Intel1
Hi Xinwei,
I've submitted an internal issue tracker for the problem.
