Intel® MPI Library
2288 Discussions
/opt/intel/oneapi/mpi/2021.13/bin/mpif90: line 655: ifx: command not found
Abdelghany
I have recently installed oneAPI intel-basekit on Rocky Linux release 8.8. Then, I used the following configuration file to compile the GPU version of BerkeleyGW (BerkeleyGW 4.0
# module use /soft/modulefiles
# module load oneapi/release/2023.12.15.001
COMPFLAG  = -DINTEL -DINTEL_GPU -DONE_API
PARAFLAG  = -DMPI -DOMP
MATHFLAG  = -DUNPACKED -DUSEFFTW3  -DUSESCALAPACK  -DHDF5  -DOMP_TARGET  -DUSEPRIMME
# DEBUGFLAG = -DDEBUG
# General options
LINK      = mpif90 -fc=ifx
REMOVE    = /bin/rm -f
# Fortran options
FCPP    = cpp -C -nostdinc -fopenmp
F90free = mpif90 -fc=ifx -free
# -O0 and -O1 pass all tests (oneapi/release/2023.12.15.001 on Aurora Jan 2024)
# FOPTS   =  -O0 -g -traceback -check shape -fp-model precise -no-ipo -align array64byte -fiopenmp -fopenmp-targets=spir64 -qmkl=sequential -lmkl_sycl -lsycl -lOpenCL
FOPTS   =  -O2 -g -traceback -check shape -fp-model precise -no-ipo -align array64byte -fiopenmp -fopenmp-targets=spir64 -qmkl=sequential -lmkl_sycl -lsycl -lOpenCL
FNOOPTS = $(FOPTS)
MOD_OPT = -module
INCFLAG = -I
# C/C++ options
C_PARAFLAG = -DPARA
CC_COMP = mpicc #-cc=icx
C_LINK  = mpicxx #-cxx=icpx
C_FOPTS = -O2 -g -traceback -check shape fp-model-precise -no-ipo -align -fiopenmp -fopenmp-targets=spir64 -lOpenCL
# Math Libraries
FFTWPATH     =
FFTWINCLUDE  = $(MKLROOT)/include/fftw/
# FFTWLIB = -qmkl=sequential --no-as-needed -lmkl_scalapack_lp64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_lp64 -liomp5 -lpthread -lm -ldl
FFTWLIB = -qmkl=sequential -lmkl_scalapack_lp64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_lp64 -liomp5 -lpthread -lm -ldl
LAPACKLIB = $(FFTWLIB)
# SCALAPACKLIB = -qmkl=sequential --no-as-needed -lmkl_scalapack_lp64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_lp64 -liomp5 -lpthread -lm -ldl
SCALAPACKLIB = -qmkl=sequential -lmkl_scalapack_lp64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_lp64 -liomp5 -lpthread -lm -ldl
HDF5_LDIR    = /usr/local/HDF5_intel/lib
HDF5LIB      = $(HDF5_LDIR)/libhdf5hl_fortran.a \
                $(HDF5_LDIR)/libhdf5_hl.a \
                $(HDF5_LDIR)/libhdf5_fortran.a \
                $(HDF5_LDIR)/libhdf5.a -lz -ldl
HDF5INCLUDE  = /usr/local/HDF5_intel/include
PRIMMELIB = /usr/local/PRIMME/lib/libprimme.a
PRIMMEINC = /usr/local/PRIMME/include/
But I got the following Errors:
mpif90 -fc=ifx -free -I ./Common -I /opt/intel/oneapi/mkl/2024.2/include/fftw/ -I /usr/local/HDF5_intel/include -c -O2 -g -traceback -check shape -fp-model precise -no-ipo -align array64byte -fiopenmp -fopenmp-targets=spir64 -qmkl=sequential -lmkl_sycl -lsycl -lOpenCL Common/lapack.p.f -o Common/lapack.o -module Common/
cpp -C -nostdinc -fopenmp  -I./Common -DCPLX -DINTEL -DINTEL_GPU -DONE_API -DMPI -DOMP -DUNPACKED -DUSEFFTW3  -DUSESCALAPACK  -DHDF5  -DOMP_TARGET  -DUSEPRIMME  Common/essl.f90 > Common/essl.p.f
/opt/intel/oneapi/mpi/2021.13/bin/mpif90: line 896: ifx: command not found
make[2]: *** [Common/common-rules.mk:281: Common/nrtype_m.mod] Error 127
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [Common/common-rules.mk:281: Common/scalapack_aux_m.mod] Error 127
make[2]: *** [Common/common-rules.mk:281: Common/blas_m.mod] Error 127
make[2]: *** [Common/common-rules.mk:281: Common/lapack_m.mod] Error 127
mpif90 -fc=ifx -free -I ./Common -I /opt/intel/oneapi/mkl/2024.2/include/fftw/ -I /usr/local/HDF5_intel/include -c -O2 -g -traceback -check shape -fp-model precise -no-ipo -align array64byte -fiopenmp -fopenmp-targets=spir64 -qmkl=sequential -lmkl_sycl -lsycl -lOpenCL Common/essl.p.f -o Common/essl.o -module Common/
make[2]: *** [Common/common-rules.mk:282: Common/essl.o] Error 127
make[2]: Leaving directory '/rhome/Ragab/source_codes/BerkeleyGW-4.0'
make[1]: *** [Makefile:8: pre] Error 2
make[1]: Leaving directory '/rhome/Ragab/source_codes/BerkeleyGW-4.0'
make: *** [Makefile:115: all] Error 2
Could anyone please guide me how to solve this problem?
Best
Ragab
TobiasK
The basekit does not contain the Intel MPI library nor the Fortran compiler. Please install the HPC kit:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/hpc-toolkit.html
TobiasK
