Intel® MPI Library
running Intel MPI 4.0 with SLURM
Avi_Purkayastha
I have just installed intel mpi (v4.0.0.027) on a nahelem-IB based cluster system which uses the SLURM resource manager. All of the compilers and mpi stacks are installed using modules, including the intel mpi. After I load the intel-mpi module, build the application, and try to run it using a SLURM batch file, the program crashes, as the intel-mpi runtime environment does not obtain all of the SLURM environments. I get the message..
mpiexec_rm1867: cannot connect to local mpd (/tmp/mpd2.console_apurkay); possible causes:
1. no mpd is running on this host
2. an mpd is running but was started without a "console" (-n option)
It does not get the information on the compute nodes and tries instead to run on the login-console which is not the place to run, and hence fails.
I assume then that the SLURM environments relating to the mpd.hosts file was not captured by the intel-mpi? If so, what runtime parameters or environments do need to pass/define in the slurm batch script?
BTW, the default setup with OMPI/OpenFabrics and SLURM works fine.
Thanks for any help.
-- Avi
Dmitry_K_Intel2
Hi Ali,
Intel MPI Library recognizes SLURM_JOBID, SLURM_NNODES, SLURM_NODELIST and some other environment variables. But you need to use mpirun to start your application. Only in this case mpd ring will be created.
You probably need to add '-nolocal' option because a node on which you start your application will be added to the ring automatically.
Regards!
Dmitry
Avi_Purkayastha
Hi Dmitry,
thanks for the pointers.
I verified that the SLURM_NODELIST was recognized and echoed that variable inside the batch script.
However when I run mpirun inside the slurm batch-script with the following options..
mpirun -np 2 -nolocal ./a.out
I am getting the following errors..
Node list is rm[1203-1204]
mpdboot_rm1203 (handle_mpd_output 905): from mpd on rm1204, invalid port info:
connect to address 10.1.4.180 port 544: Connection refused
trying normal rsh (/usr/bin/rsh)
rm1204: Connection refused
What am I missing? I can print out other relevant SLURM variables to obtain additional clues.
-- Avi
Dmitry_K_Intel2
Hi Avi,
Are you using rsh or ssh connection between nodes?
If you are using ssh you need to provide '-r ssh' option.
Please be sure that there is passwordless connection and you can login both from rm1203 to rm1024 and vice versa.
Regards!
Dmitry
reuti_at_intel
passwordless (better: passphraseless) ssh needs to be set up for each user, and they might be tempted to copy these keypairs to other systems to ease their login. It's advantageous to have a hostbased login instead:
http://gridengine.sunsource.net/howto/hostbased-ssh.html
-- Reuti
Avi_Purkayastha
we are using passphraseless ssh, and have used it with our other MPI installs with SLURM. However when I tried running adding the '-r ssh' as an mpirun run option with the intel-mpi, I keep getting the same error message..
Node list is rr[108,129]
mpdboot_rr108 (handle_mpd_output 905): from mpd on rr129, invalid port info:
connect to address 10.1.0.129 port 544: Connection refused
Node list is rr[108,129]mpdboot_rr108 (handle_mpd_output 905): from mpd on rr129, invalid port info:connect to address 10.1.0.129 port 544: Connection refusedconnect to address 10.1.0.129 port 544: Connection refusedtrying normal rsh (/usr/bin/rsh)
I also looked at the 'mpirun --help', and did not see '-r ssh' as an option that was listed. In fact there were no options listed for using ssh.
-- Avi
TimP
mpirun -help
--rsh specifies the name of the command used to start remote mpds; it
defaults to rsh; an alternative is ssh
--shell says that the Bourne shell is your default for rsh'
--verbose shows the ssh attempts as they occur; it does not provide
confirmation that the sshs were successful
mpirun -version
Intel MPI Library for Linux Version 4.0
Build 20100422 Platform Intel 64 64-bit applications
As Dmitry said, you must try stand-alone ssh in both directions among the offending nodes, from the relevant account, to guard against problems such as ~/.ssh/known_hosts containing stale information.
mpdboot (with the appropriate nodelist) followed by mpdtrace and mpdallexit can be used for one-time check on this problem without actually waiting for a chance to run the entire application.
Avi_Purkayastha
I had set N=n=2 in the slurm script so one proc in each node were to communicate with each other. When I ran
Node list is rm[1562-1563]
% mpdboot-n 2 -v -r ssh
I got back..
totalnum=2 numhosts=1
there are not enough hosts on which to start all processes
mpdtrace
mpdtrace: cannot connect to local mpd (/tmp/mpd2.console_apurkay); possible causes:
This may be the reason why mpirun is not running as mpd is not running, given that a compute node from where the job is launched is also the host and a compute node at the same time.
Any suggestions for a fix?
-- Avi
Dmitry_K_Intel2
Avi,
By default, mpdboot is looking for mpd.hosts in the current directory to get information about nodes. Mpdboot doesn't recognize SLURM settings!
If you don't have mpd.hosts file use '-f hosts_file.txt'
In your case it might look like: 'mpdboot -f $SLURM_NODELIST -n 2 -r ssh'
Regards!
Dmitry
Avi_Purkayastha
Hi Dimitry,
I made the change that you suggested in the script file..
% mpdboot -f $SLURM_NODELIST -n 2 -v -r ssh
% mpdtrace
Unfortunately the result is the same as before..
mpdboot hostlists
mpdtrace
mpdtrace: cannot connect to local mpd (/tmp/mpd2.console_apurkaya); possible causes:
So it appears the key to the problem to be resolved is for recognition of the mpd.hosts file or equivalent by mpdboot, which is still not happening.
Cheers
-- Avi
Dmitry_K_Intel2
Avi,
Could you print out $SLURM_NODELIST? (echo $SLURM_NODELIST)
Regards!
Dmitry
Dmitry_K_Intel2
Avi,
Just one thought:
Do you run your commands after salloc? Or might be you use sbatch or srun commands?
Could you provide details about all commands used to start an application?
Regards!
Dmitry
Avi_Purkayastha
I have actually been doing that. I may not have cut-pasted it on the messages on this thread. But here is a snippet from the batch script and the latest output file...
In the batch script, I have ..
echo "Node list is" $SLURM_NODELIST
In the output file, I get..
Node list is rr[10,72]
-- Avi
Avi_Purkayastha
Dmitry,
We use a batch slurm script using sbatch, srun and mpirun. We do not use salloc, although there is nothing to prevent us from using salloc.
Here is a simple SLURM batch script that we have used. We use something like "% sbatch intel.batch" to submit the job where intel.batch looks something like..
#!/bin/bash
#SBATCH --time=01:00:00 # WALLTIME
#SBATCH -N 2 # Number of nodes
#SBATCH -n 2 # Number of cores/processors
#SBATCH -o intel-mpi-%j.log
#SBATCH -p pbatch
#SBATCH --job-name intel-mpi-test # job name
### testing mpd ###
### module load intelMPI/4.0.0.027
echo "mpdboot hostlists"
echo "mpdtrace"
mpdtrace
echo "mpdallexit"
mpdallexit
mpirun -np 2 -nolocal --ssh ./a.out
Cheers
-- Avi
Dmitry_K_Intel2
Avi,
and what is the output when you run "% sbatch intel.batch"?
Regards!
Dmitry
Avi_Purkayastha
When the job is submitted, there is a normal response with a job id # coming back.
rrlogin1<8>sbatch intel-rr.batch
Submitted batch job 3852
rrlogin1<8>sbatch intel-rr.batchSubmitted batch job 3852
-- Avi
Dmitry_K_Intel2
Avi,
In your script intel-rr.batch, please remove "mpdboot -f $SLURM_NODELIST -n 2 -v -r ssh" - you cannot use 'mpdboot'! You need to use mpirun instead.
Change your command line for mpirun:
mpirun -r ssh -nolocal -np 2 ./a.out
Check the log after "sbatch intel-rr.batch" - the format of node list ('rr[10,72]') should be parsed correctly.
Please provide the output if the problem persists.
Regards!
Dmitry
Avi_Purkayastha
Dmitry,
I had originally tried just with mpirun only to no avail. So here's the complete run script and output..
<--- run script
#!/bin/bash
#SBATCH --time=10:00 # WALLTIME
#SBATCH --job-name intel-mpi_test # Name of job
##SBATCH -p inter # see "Queues" section for details
#SBATCH -o intel-mpi-rr.out.%j
cd /home/apurkaya/apps/OMB-3.1.1/intel-mpi/tests/2-node
mpirun -r ssh -nolocal -np 2 ./osu_bw
<--- output
Node list is rr[76-77]
mpdboot_rr76 (handle_mpd_output 846): mpdboot: can not get anything from the mpd daemon; please check connection to rr77
Dmitry_K_Intel2
Avi,
mpirun was able to parse host name correctly.
Please check that you are able to login on node rr77 from rr76 and vice versa without entering password:
ssh rr77
(from rr77) ssh rr76
Regards!
Dmitry
Andrey_D_Intel
Avi,
Could you try the following scenario?
I assume that you have hello application. It may be any simple MPI test
1. Create test.sh file. For instance,
$ cat test.sh
#!/bin/bash
srun hostname -s | sort -u >mpd.hosts
source /opt/mpi-4.0.026/bin64/mpivars.sh
# Example 1
# Launch application using hydra process manager
mpiexec.hydra -f mpd.hosts -n $SLURM_NPROCS -env I_MPI_DEBUG 5 ./hello
# Example 2
# Launch application using MPD process manager
mpdboot -n $SLURM_NNODES -r ssh
mpiexec -n $SLURM_NPROCS -env I_MPI_DEBUG 5 ./hello
mpdallexit
2. submit a job using sbatch command. For instance,
$ sbatch -n 4 test.sh
Please let me know how the suggestion help.
Andrey
