Intel® MPI Library
shm:dapl mode crashes when using MLNX OFED 2.1-1.0.0
Tommi_T_
Simple mpi-helloworld mpi program crashes when using shm:dapl mode and MLNX OFED 2.1-1.0.0 IB stack. shm:ofa works fine. shm:dapl mode used to work fine with MLNX OFED 1.5.3 but latest el6.5 kernel requires 2.1-1.0.0 version.
intelmpi/4.1.3
I_MPI_FABRICS=shm:dapl srun -pdebug -n2 -N2 ~/mpi/intelhellog
srun: job 830396 queued and waiting for resources
srun: job 830396 has been allocated resources
c578: Before MPI_INIT
c577: Before MPI_INIT
srun: error: c578: task 1: Segmentation fault (core dumped)
srun: Terminating job step 830396.0
srun: error: c577: task 0: Segmentation fault (core dumped)
(gdb) bt
#0  0x00007f222c9ad85c in I_MPI_dat_extension_op (handle=0x1e5e770, ext_op=6)
    at ./../../include/I_MPI_wrap_dat.h:352
#1  0x00007f222c9b0b56 in dapl_rc_init_infostructure_20 (proc=0x7f222d02e040,
    param=0x7fffe3b5d6c8, rc_proc=0x7f222d02db00, rc_param=0x7fffe3b5d650,
    rc_secondary_proc_params=0x7f222d02dfe0, p_ia_attr=0x7fffe3b5d068,
    p_provider_attr=0x7fffe3b5d318) at ../../dapl_init_rc.c:948
#2  0x00007f222c9aea39 in MPID_nem_dapl_rc_init_20 (params=0x7fffe3b5d6c8,
    rc_params=0x7fffe3b5d650, pg_p=0x1e41480, pg_rank=1, fallback_device=0,
    provider_found=0x7fffe3b5d64c) at ../../dapl_init_rc.c:207
#3  0x00007f222ca10b0c in MPID_nem_dapl_init (pg_p=0x1e41480, pg_rank=1,
    bc_val_p=0x7fffe3b5d980, val_max_sz_p=0x7fffe3b5da98) at ../../dapls_module_init.c:437
#4  0x00007f222caf41a7 in MPID_nem_impi_netmod_init (pg_rank=1, pg_p=0x1e41480,
    ckpt_restart=0, bc_val=0x1e41bb0 "", pval_max_remaining=0x7fffe3b5da98,
    num_processes=2) at ../../mpid_nem_init.c:146
#5  0x00007f222caf7482 in MPID_nem_init_ckpt (pg_rank=1, pg_p=0x1e41480, ckpt_restart=0,
    has_parent=0) at ../../mpid_nem_init.c:859
#6  0x00007f222caf563e in MPID_nem_init (pg_rank=1, pg_p=0x1e41480, has_parent=0)
    at ../../mpid_nem_init.c:490
#7  0x00007f222c8f6a2a in MPIDI_CH3_Init (has_parent=0, pg_p=0x1e41480, pg_rank=1)
    at ../../ch3_init.c:64
---Type <return> to continue, or q <return> to quit---
#8  0x00007f222cad5244 in MPID_Init (argc=0x7fffe3b5e8a8, argv=0x7fffe3b5e8b0,
    requested=0, provided=0x7fffe3b5e4c0, has_args=0x7fffe3b5e4c4, has_env=0x7fffe3b5e4c8)
    at ../../mpid_init.c:193
#9  0x00007f222caa3019 in MPIR_Init_thread (argc=0x7fffe3b5e8a8, argv=0x7fffe3b5e8b0,
    required=0, provided=0x7fffe3b5e6bc) at ../../initthread.c:539
#10 0x00007f222ca90190 in PMPI_Init (argc=0x7fffe3b5e8a8, argv=0x7fffe3b5e8b0)
    at ../../init.c:195
#11 0x0000000000400a81 in main (argc=1, argv=0x7fffe3b5e9c8) at hello.c:26
(gdb) bt full
        ret = 0
        args = {{<No data fields>}}
        dapl_handle = 0x1
        ret = 0
        region = {for_va = 0x1ea3b78, for_lmr_handle = 0x1ea3b78, for_shared_memory = {
            virtual_address = 0x1ea3b78, shared_memory_id = 0x7f2229656260}}
        dummy_registered_size = 4096
        dummy_registered_addr = 32127864
        dummy_rkey = 805377050
        fcname = 0x0
        mpi_error = 1
        i = 1
        vbuf_header_size = 1
        rtc_err = 1
        pg_size = 2
        ia_attr = {adapter_name = "mlx4_0", '\000' <repeats 249 times>,
          vendor_name = '\000' <repeats 255 times>, hardware_version_major = 1,
          hardware_version_minor = 0, firmware_version_major = 0,
          firmware_version_minor = 0, ia_address_ptr = 0x1e42168, max_eps = 393080,
          max_dto_per_ep = 16351, max_rdma_read_per_ep_in = 16,
          max_rdma_read_per_ep_out = 128, max_evds = 65408, max_evd_qlen = 4194303,
          max_iov_segments_per_dto = 32, max_lmrs = 524032,
          max_lmr_block_size = 4294967295, max_lmr_virtual_address = 18446744073709551615,
          max_pzs = 32764, max_message_size = 1073741824, max_rdma_size = 1073741824,
          max_rmrs = 0, max_rmr_target_address = 18446744073709551615, max_srqs = 0,
          max_ep_per_srq = 0, max_recv_per_srq = 0, max_iov_segments_per_rdma_read = 32,
          max_iov_segments_per_rdma_write = 32, max_rdma_read_in = 16,
          max_rdma_read_out = 128, max_rdma_read_per_ep_in_guaranteed = DAT_TRUE,
          max_rdma_read_per_ep_out_guaranteed = DAT_TRUE, zb_supported = DAT_FALSE,
          extension_supported = DAT_EXTENSION_IB, extension_version = 207,
          num_transport_attr = 0, transport_attr = 0x0, num_vendor_attr = 0,
          vendor_attr = 0x0}
        provider_attr = {provider_name = "ofa-v2-mlx4_0-1", '\000' <repeats 240 times>,
          provider_version_major = 2, provider_version_minor = 0, dapl_version_major = 2,
          dapl_version_minor = 0, lmr_mem_types_supported = 3,
          iov_ownership_on_return = DAT_IOV_CONSUMER,
          dat_qos_supported = DAT_QOS_BEST_EFFORT,
          completion_flags_supported = DAT_COMPLETION_DEFAULT_FLAG,
          is_thread_safe = DAT_FALSE, max_private_data_size = 118,
          supports_multipath = DAT_FALSE, ep_creator = DAT_PSP_CREATES_EP_NEVER,
          pz_support = DAT_PZ_UNIQUE, optimal_buffer_alignment = 256,
          evd_stream_merging_supported = {{DAT_TRUE, DAT_TRUE, DAT_TRUE, DAT_TRUE,
              DAT_TRUE, DAT_FALSE}, {DAT_TRUE, DAT_TRUE, DAT_TRUE, DAT_TRUE, DAT_TRUE,
              DAT_FALSE}, {DAT_TRUE, DAT_TRUE, DAT_TRUE, DAT_FALSE, DAT_TRUE, DAT_FALSE}, {
              DAT_TRUE, DAT_TRUE, DAT_FALSE, DAT_TRUE, DAT_TRUE, DAT_FALSE}, {DAT_TRUE,
              DAT_TRUE, DAT_TRUE, DAT_TRUE, DAT_TRUE, DAT_FALSE}, {DAT_FALSE, DAT_FALSE,
              DAT_FALSE, DAT_FALSE, DAT_FALSE, DAT_FALSE}}, srq_supported = 2147483647,
          srq_watermarks_supported = 0, srq_ep_pz_difference_supported = DAT_TRUE,
          srq_info_supported = 0, ep_recv_info_supported = 31726976,
          lmr_sync_req = DAT_FALSE, dto_async_return_guaranteed = 18,
          rdma_write_for_rdma_read_req = 32767,
          rdma_read_lmr_rmr_context_exposure = DAT_FALSE, rmr_scope_supported = 32767,
          is_signal_safe = 751259856, ha_supported = 32546, ha_loadbalancing = 751259872,
          num_provider_specific_attr = 12, provider_specific_attr = 0x7f21e832da20}
        local_ia_addr = {sa_family = 1,
          sa_data = "\000\000\001\000\000\000\000\000\000\000\377\177\000"}
        rtc_attr = {struct_size = 5, max_memory_size = 8182128, max_cache_entries = 0,
          lazy_mem_unregister = 0, min_memblock_size = 0,
          dont_use_overlapping = RTC_OVERLAP_ALLOWED, avl_block_size = 0,
          use_avl_tree = 746536960, rtc_register_fn = 0x7f222d26dff0 <_dl_fixup+224>,
          rtc_unregister_fn = 0x200000005, info = 0x0}
        dapl_index = 0
        proc = 0x7f222d02e040
        rc_secondary_proc_params = 0x7f222d02dfe0
        rc_proc = 0x7f222d02db00
        __I_MPI_dat2_lib_names__ = {0x7f222cc750d0 "libdat2.so.2",
          0x7f222cc750e0 "libdat2.so"}
        libdat_names = 0x7fffe3b5d050
        nlibdat = 2
        mpi_errno = 0
        fallback_device = 0
        num_providers_in_datconf = 27
        provider_found = 0
        i = 0
        check_provider_from_all_processes = 0
        nproviders = 1
        default_params = {{create_conn_qual = 1, rdma_use_mreg_cache = 1,
            vbuf_total_size = 23808, rtc_max_cache_entries = 1024,
            rtc_max_memory_size = 0, rtc_use_avl_tree = 0, rtc_avl_block = 32546,
            req_evd_qlen = 2000, conn_evd_qlen = 36, rdma_optimal_buffer_align = 0,
            rdma_dont_use_rtc_overlapping = 0}, {create_conn_qual = -474623584,
            rdma_use_mreg_cache = 32767, vbuf_total_size = 705030728,
            rtc_max_cache_entries = 32546, rtc_max_memory_size = 140737013734464,
            rtc_use_avl_tree = -474622112, rtc_avl_block = 32767,
            req_evd_qlen = 749592018, conn_evd_qlen = 32546,
            rdma_optimal_buffer_align = 0, rdma_dont_use_rtc_overlapping = 0}, {
            create_conn_qual = 735235728, rdma_use_mreg_cache = 0,
            vbuf_total_size = 696639508, rtc_max_cache_entries = 0,
            rtc_max_memory_size = 140733193388033, rtc_use_avl_tree = 0,
            rtc_avl_block = 32767, req_evd_qlen = 4196624, conn_evd_qlen = 0,
            rdma_optimal_buffer_align = 3820349888, rdma_dont_use_rtc_overlapping = 32767}}
        default_ud_params = {ud_default_recv_evd_qlen = 48769090,
          ud_recv_buf_total_size = 0, ud_send_buf_total_size = -474622312,
          rndv_ep_ud_max_dtos = 32767, can_use_ud_ext = 1}
        default_rc_params = {rdma_default_max_wqe = 400, rdma_default_max_recv_wqe = 8,
          rdma_req_wqe_reserve = 32, rdma_check_max_rdma_attr = 0,
          rdma_eager_msg_aggregation = 0, dapl_scalable_read_progress = 0}
        mpi_errno = 0
        netmod_configuration = 1
        netmod_index = 1
        i = 0
        mpi_errno = 0
        num_procs = 2
        ret = 0
        num_local = 1
        local_procs = 0x1e410b0
        local_rank = 0
        index = 128
        i = 32546
        publish_bc_orig = 0x1e41bb0 ""
        bc_val = 0x1e41bb0 ""
        val_max_remaining = 256
        grank = 2
        fastboxes_p = 0x7f222985e080
        cells_p = 0x7f222985e0c0
        network_cells_p = 0x0
        recv_queues_p = 0x7f222a05e140
        free_queues_p = 0x7f222a05e0c0
        envvar = 0x7f22fbad8001 <Address 0x7f22fbad8001 out of bounds>
        envname = 0x7f222ba9cda0 "H9\\$8t\bH\213T$(\306\002"
        num_cpus = 0
        netmod_configuration = 729385136
        check_fabrics_compatibility = 0
        sshmqs_p = 0x0
        sshmconns_p = 0x0
        mpiu_chkpmem_stk_ = {0x1e41cc0, 0x1e41090, 0x1e41070, 0x1e41d40, 0x1e40e90,
          0x7fffe3b5dd00, 0x1e418f0, 0x7fffe3b5ddf0, 0x1}
        mpiu_chkpmem_stk_sp_ = 5
        mpiu_chkpmem_stk_sz_ = 9
No locals.
        mpi_errno = 0
        i = 0
        mpi_errno = 0
        has_parent = 0
        pg = 0x1e41480
        pg_rank = 1
        pg_size = 2
        comm = 0x7f222d47d358
        p = 746568848
        envvar = 0x0
        envname = 0x7f222ccf8ed4 "I_MPI_IPROBE_SPIN_COUNT"
        attr_val = 0x0
        mpi_errno = 0
        has_args = 1
        has_env = 1
        thread_provided = 0
        exit_init_cs_on_failure = 1
        envvar = 0x100000000 <Address 0x100000000 out of bounds>
        envname = 0x100000000 <Address 0x100000000 out of bounds>
        interaction = 0x0
    at ../../init.c:195
        FCNAME = "MPI_Init"
        mpi_errno = 0
        rc = 0
        threadLevel = 0
        provided = 32546
        dtm = 0
        rank = 32546
        size = 0
        len = 0
        name = "\001\000\000\000\000\000\000\000\210\021H-\"\177\000\000\210\350\265\343\377\177\000\000v\000\000\000\000\000\000\000\t\000\000\000\000\000\000\000\236\350\265\343\377\177\000\000\000\000\000\000\000\000\000\000\340\024H-\"\177\000\000\260\350\265\343\377\177\000\000\207֢+\"\177\000\000\310\350\265\343\377\177\000\000\211W\251+\001\000\000\000\000\000H-\"\177\000\000\006\006@\000\000\000\000\000\302\000\000\000\000\000\000\000\236\350\265\343\377\177\000"
        to_wait = 0
        sleep_diff = 0
        max_limit = 0
        sleep_start = 0
        sleep_now = 0
        hostname = "c578\000\000\000\000\000\000\000\000\001\000\000\000\371\a\000\000\001\0---Type <return> to continue, or q <return> to quit---
00\000\000Z\236&-\"\177\000\000\000\000\000\000\000\000\000\000\340\024H-\"\177\000\000\000\351\265\343\377\177\000\000(\351\265\343\377\177\000\000\210\021H-\"\177\000\000X\327F-\"\177\000\000.N=\366\000\000\000\000Z\236&-\"\177\000\000\000\000\000\000\000\000\000\000X\327F-\"\177\000\000\001", '\000' <repeats 14 times>
(gdb) bt full
        ret = 0
        dapl_handle = 0x1
        ret = 0
        fcname = 0x0
        mpi_error = 1
        i = 1
        rtc_err = 1
        pg_size = 2
          vendor_attr = 0x0}
        dapl_index = 0
        nlibdat = 2
        mpi_errno = 0
        fallback_device = 0
        provider_found = 0
        i = 0
        nproviders = 1
        mpi_errno = 0
        netmod_index = 1
        i = 0
        mpi_errno = 0
        num_procs = 2
        ret = 0
        num_local = 1
        local_rank = 0
        index = 128
        i = 32546
        grank = 2
        num_cpus = 0
        sshmqs_p = 0x0
        sshmconns_p = 0x0
No locals.
        mpi_errno = 0
        i = 0
        mpi_errno = 0
        has_parent = 0
        pg = 0x1e41480
        pg_rank = 1
        pg_size = 2
        p = 746568848
        envvar = 0x0
        attr_val = 0x0
        mpi_errno = 0
        has_args = 1
        has_env = 1
        thread_provided = 0
        interaction = 0x0
    at ../../init.c:195
        FCNAME = "MPI_Init"
        mpi_errno = 0
        rc = 0
        threadLevel = 0
        provided = 32546
        dtm = 0
        rank = 32546
        size = 0
        len = 0
        to_wait = 0
        sleep_diff = 0
        max_limit = 0
        sleep_start = 0
        sleep_now = 0
James_T_Intel
Hi Tommi,
Thank you for this report.  I have submitted this to our developers for further investigation.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
Tommi_T_
Sorry I forgot to update solution here, latest Mellanox OFED_LINUX v2.1-1.0.6 does not crash anymore, Mellanox compiled dapl without proprietary FCA support.
James_T_Intel
Hi Tommi,
Thanks for the update.  I'll let our developers and other users know.
Sincerely,
James Tullos
