Intel® MPI Library
2274 Discussions
unable to write Lammps dump files
asif1
I have compiled the latest version of Lammps using gcc with intel-onepi-mpi successfully, I am writing dump and restart files at certain iterations during lammps run. The job will start and run fine, but the job will stop to write the dump file and continues to run using 100% of cpu, no error or output message gets updated. The job just hangs, I have no issues running the job using openmpi. Any help is appreciated.
Asif.
SantoshY_Intel
Hi Asif,
Thank you for posting in the Intel communities.
To help us better understand the issue, we kindly request that you provide us with the following details:
  1. The version of Intel MPI you're currently using.
  2. A sample reproducer code that highlights the issue you're facing, instead of sharing the whole application.
  3. The steps you followed to reproduce the issue.
  4. The operating system you're using.
  5. The CPU on which you're running the application.
Santosh
asif1
Hello Santosh,
      Sorry for the late response.
      The version of Intel MPI you're currently using. - intel-oneapi-mpi@2021.8.0
      The steps you followed to reproduce the issue. -
              export I_MPI_DEBUG=5
              export FI_PROVIDER=mlx
              time mpirun -np $SLURM_NTASKS lmp -in input
      The operating system you're using. - AlmaLinux release 8.7 (Stone Smilodon)
      The CPU on which you're running the application - AMD EPYC 7713 64-Core Processor
I have not attached any of my files here. let me know if you need them.
Asif.
SantoshY_Intel
We haven't heard back from you. Could you please provide us with the above requested details to investigate your issue?
Thanks & Regards,
Santosh
SantoshY_Intel
Thank you for your inquiry. We can only offer direct support for Intel hardware platforms that the Intel® oneAPI product supports. Intel provides instructions on how to compile oneAPI code for both CPU and a wide range of GPU accelerators.
https://intel.github.io/llvm-docs/GetStartedGuide.html
We can see that your processor and operating system don't meet the Intel MPI system requirements. We recommend you try using an Intel processor & supported operating system as mentioned in the below system requirements page:
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/mpi-library-system-requirements.html
If you still face the same issue, then please provide us with a sample reproducer code to investigate your issue from our end.
Thanks & Regards,
Santosh
SantoshY_Intel
We haven't heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Santosh
SantoshY_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Santosh
