About timer.pas ...
aminer10
Inside parallelhashlist.zip i have put a new timer.pas that compiles correctly
under both Win32 and Win64, i have changed  the Tick method inside
timer.pas and added the 64 bits parts so  that it works correctly under
Win64:
Here is the new Tick method:
function TLkBaseTimer.Tick: int64; register;
//asm
 // rdtsc;
//db 0fh, 31h
//end;
asm
  rdtsc
{$IFDEF CPU64}
  shl   rdx, 32
  or    rax, rdx
{$ENDIF CPU64}
end; { GetCPUTimeStamp }
How to use the timer to time in microseconds ?
Like this:
Call Timestart() first like this:
HPT.Timestart;
and after that you can write the Time in microseconds like this
writeln('Time in microseconds: ',hpt.TimePeriod);
Please look inside test1.pas inside parallelhashlist.zip i have given you
an example on how to use timer.pas to time the throuput of your multithreaded
program...
You can download parallelhashlist from:
http://pages.videotron.com/aminer/
Sincerely,
Amine Moulay Ramdane,
