1707 Discussions
Adding border bands, padding instead of rescaling while transcoding
shavkat_n_
Doing video transcoding with different aspect ratio
Input :
Codec Type          : Advanced Video Coding (H.264) (AVC1)
 Format Profile      : [email protected]
 CABAC               : Yes
 Image Size          : 1280 x 536 (160 : 67)
 Frame Rate          : 7200.00 Frame/Sec
Output:
 CABAC               : No
 Image Size          : 1280 x 720 (16 : 9)
 Average Bit Rate    : 1.84 MBits/Sec
 Frame Rate          : 35.00 Frame/Sec
As you can see aspect is changed, and frame height is changed which is ok. But by default frame is scaled in height ( frame is unnaturally elongated in height, example: round face becomes oval face, ie: longer face), but need to keep original picture ratio but add border padding on top, bottom instead.
How can it be transcoded without rescaling/resizing picture but just adding border padding on top and bottom position?
Which parameters in Intel Media sdk needs to be changed ?
I couldn't get meaningful info from mfxVideoParam. mfxFrameInfo has  AspectRatioW, AspectRatioH  & crop x,y,w,h. Do I have to use that?
Please provide steps, parameters...
jimdempseyatthecove
Add 92 rows(lines) at the top and 92 at the bottom, each row(line) 1280. Choose whatever color you want.
IOW preallocate 720 lines of 1280, prefill top 92 and bottom 92 with color of choice, and either copy frames into buffer at 92*128, or use that as your input frame and avoid the copy.
Jim Demspey
shavkat_n_
Thank you Jim
