1704 Discussions
(CL_DEVICE_NOT_FOUND) show when run app from console windows
waltermdq
Hello
the example run properly on release and debug inside of visual studio 2019, but not run when run from windows console. i test with gpu, cpu but not works outside of visual studio
#include <CL/sycl.hpp>
#include <iostream>
using namespace sycl;
// Demonstrate vector add both in sequential on CPU and in parallel on device.
int main(int argc, char* argv[]) {
// The default device selector will select the most performant device.
// default_selector d_selector;
try {
queue q{ cpu_selector{} };
// Print out the device information used for the kernel code.
std::cout << "Running on device: "
<< q.get_device().get_info<info::device::name>() << "\n";
} catch (exception const &e) {
std::cout << "An exception is caught for vector add.\n";
std::cerr << e.what();
std::terminate();
system("pause");
system("pause");
return 0;
