Catasprophic compiler failure
Paulius_V_
Hello. I've encountered an a compiler failure when trying to compile a file with -02 and above. This happens on both 2016 and 2017 versions on Linux. Seems to happen after an inclusion of a parallel openmp simd region. Is threre a way to make the compiler spit out some sort of a report or get any additional insight as to why?
Cannot publish the source code.
Paulius_V_
Found what was causing it:
#IFDEF A
!$omp parallel do simd default(shared) schedule(static)
#IFDEF B
!$omp simd
#ENDIF
#ENDIF
DO I=AA,BB
ENDDO
taking out the simd out of 'do simd' fixed it. Is there any difference in inlining the simd clause as opposed to having it on the next directive?
TimP
Effect of pre-standard simd directive and openmp4 may not be always identical. Ideally compiler should warn about possible conflict.
