Compilation Error for Intel Threading Tools
Intel_C_Intel
When I compile my code with /Qtcheck switch, Although the VTune and Thread checker is installed I get the following errors
(0) catastrophic error : tcheck10.ini not found; Intel threading tools must be installed
What can be the reason for this ?
Good days
Cem DEMiRKIR
Henry_G_Intel
Hello Cem,
Are you compiling within Microsoft Visual Studio or from the command prompt? Is the C:Program FilesIntelVTune checkin directory in your PATH?
Henry
Message Edited by hagabb on 05-05-2006 09:37 AM
Intel_C_Intel
I use VS 2003 with Intel 9.0. I built it form the project build button. Yes the directory is in my environment variables. It is saved as
"ITT_CHECK = d:programsIntelVTunecheck" and
"Path = %ITT_CHECK%in"
Cem
David_M_Intel3
Hello Cem,
Please check the following items:
The path you listed omits a t in front of check. Typically the install uses tcheck. So a typical installation would list the following:
ITT_TCHECK=C:Program FilesIntelVTune check
Please check the Visual Studio settings. The following should be set:
In Visual Studio, go to Tools/Options/Projects/VC++ Directories
Drop-down Executables:
add C:Program FilesIntelVtuneAnalyzerin
Drop-down Libraries:
add C:Program FilesIntelVtuneAnalyzerlib
If check the box for automatically updatingenvironment when installing bothIntel compiler and Intel Thread Checker and the compiler is installed first, this is done automatically. If the automatic update box is not selected at install time or the compiler is installed after Intel Thread Checker then this needs to be set manually as indicated above.
Get quicker responses to support questions at https://premier.intel.com
-drm
