DLLs and Common block
moncef
I used Help files in IVF, "Coding Requirements for Sharing Data in DLLs", "Exporting and Importing Common Block Data", where example of appropriate DLLEXPORT directive is included and described. When I create a dll and I put common blocks that I want to be linked to the same common block in my exe program, the common block information does not pass from the exe to the dll.
How can I declare common block in both the main exe and any dll and having the information passing?
The code source of the DLL is:
subroutine Seta
use user32
use kernel32
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"Seta":: Seta
!DEC$ ATTRIBUTES DLLEXPORT:: Seta, /X/
implicit none
common /X/C,B,A
real C,B,A
A=A+1
B=B+1
return
end subroutine Seta
The subroutine in the main program that uses the DLL is:
subroutine test
use user32
use kernel32
implicit none
pointer (p_seta, seta)
integer(HANDLE) :: dll_handle
integer(BOOL) :: free_status
integer i
real AP
common /X/C,B,A
real C,B,A
Interface
subroutine Seta
!DEC$ ATTRIBUTES DLLIMPORT:: Seta, /X/
implicit none
common /X/C,B,A
real C,B,A
end subroutine Seta
end interface
dll_handle = LoadLibrary ("DLL_a.dll"C)
! Check for errors
if (dll_handle == NULL) then
! Failure
stop
end if
p_seta = GetProcAddress (dll_handle, "Seta"C)
if (p_Seta == NULL) then
! Failure
stop
end if
! Now call the function
call seta ! the value of A in the DLL is 1
Ap=A ! the value of A in the subroutine test is 0 so Ap=0
free_status = freelibrary(p_seta)
end subroutine Test
If you have a solution, pelase send me a simple example.
thanks in advance
TimP
Check the examples which come with your compiler. Don't try to mix conventions from different eras. Look up examples discussed on the Windows Fortran forum, and ask questions there.
