Debug mic in Windows7
Victor_Z_1
 When I typed   "micnativeloadex MyTest -d 0" in Windows 7 to debug  MyTest.exe ( mic + OpenMP), I got the error  message below:
Unable to create remote process.
ssh to the coprocessor and run ps to verify the coi_daemon
is executing.
It may be necessary to restart the mpss service.
     But there is no problem to run mic+openmp application.  I follow Intel debugger extersion for Intel MIC -VC2012. But it did work. How to debug it?
Thank you in advance.
TimP
Few MIC experts will be watching this unmoderated forum.   I'm surprised that the MIC Windows forum appears to have been cancelled; you might ask about that on the general MIC forum.
I'm not sure that your terminology is clear.  I suppose you are using OpenMP offload extensions.  If you are running on MIC alone, it may be better to use native debugging.
