Distributed Reader-Writer Mutex by Dmitry Vyukov
aminer10
Hello all;
I have loolked at the Distributed Reader-Writer Mutex by Dmitry Vyukov, look at
http://www.1024cores.net/home/lock-free-algorithms/reader-writer-problem/distributed-reader-writer-mutex
and i have looked at it and i think there is a problem with this method, cause look
at the write lock function:
int         distr_rw_mutex_wrlock           (distr_rw_mutex_t* mtx)
    int                     i;
    for (i = 0; i != mtx->proc_count; i += 1)
        pthread_rwlock_wrlock(&mtx->cell.mtx);
    return 0;
What is wrong with it ? suppose two or more writers wants to lock this distributed rwlock
there is a possibility of a deadlock.
So i think you have to use a critical section around the for loop to be able to lock
all the rwlocks at the same time to avoid the deadlock problem..
Am i correct or not ?
Thank you,
Amine Moulay Ramdane.
aminer10
> to lock
I mean  you have to use a critical section around the for loop to be able
to lock all the rwlocks atomicly  to avoid the deadlock problem..
Thank you,
aminer10
Sorry for my english: i mean atomically.
Thank you,
Amine Moulay Ramdne.
aminer10
Patricia Shanahan wrote:
> The text explanation on the referenced web page says 'No additional
> synchronization between writers is required, writers acquire the mutexes
> in the same order (from 0 to P-1), so ownership over mutex 0 basically
> determines who is the "current" writer (all other potential writers are
> parked on mutex 0).'
You are absolutly right.
Thank you,
aminer10
Thank you,
