GUI using microcontroller
Derp_K_
Hello
I want to design a Graphical User Interface to monitor a system which include dynamic robots , so the GUI must update the data depending on the serial information from robots
Any suggestions ?
Derp_K_
Waiting you suggestions
jimdempseyatthecove
Do you have any programming experience with writing a GUI application? If so, pick what you are most familiar with for writing dialog boxes. Just about every GUI programming language supports I/O to a serial port.
Jim Dempsey
Derp_K_
Jim Dempsey
Hi jim
I can use C# with visual studio
jimdempseyatthecove
For C# you generally have
using System.IO.Ports;
You should be able to Google examples (look first at those from msdn.microsoft.com).
Google Search: SerialPort class
Jim Dempsey
gaston-hillar
Valued Contributor I
Derp,
What you mention seems to be a typical IoT project where many Intel® products can make your job really easier.
Are you familiar with the Intel® Galileo Gen 2 development board and the cloud-based analytics system provided on the IoT Analytics site?
You can read about the combination of an Intel® IoT platform and the cloud-based analytics system provided on the IoT Analytics site here: http://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics
Hope it helps.
Derp_K_
Jim Dempsey
Thanks jim , i will google it
Derp_K_
gaston-hillar wrote:
Derp,
Hope it helps.
It sounds interesting , i will check that
Thank you gaston
gaston-hillar
Derp K. wrote:
Derp,
Hope it helps.
Thank you gaston
You will find a huge amount of valuable information related to IoT projects at Intel® Developer Zone. Also, check the videos because they provide really valuable tutorials to get you started.
Derp_K_
Thanks again , it will be great data for my project
Derp_K_
If this system is used in a specific company and they would like to have their own cloud , the intel Iot kits and device would be compatible with it , or they are just designed for IoT analytics of intel
gaston-hillar
Derp,
You can create an account on Intel IoT Analytics and activate your device to work with it. However, are you working with an Intel Galileo or Intel Edison board?
