HPL and MKL 11.1 (064) Seg fault
i1ya
Hi everyone!
I've installed Intel C++/Fortran Compiler Professional Edition for Linux with MKL to my cluster. And I have problem while running HPL compiled with MKL.
Cluster node:
CPU: 2 x Intel Xeon CPU E5450
Network: Ethernet/Infiniband
Memory: 16 Gb.
OS: CentOS 5.4
MPI:
openmpi-1.4 (using Intel compilers).
HPL make file:
SHELL = /bin/sh
CD = cd
CP = cp
LN_S = ln -s
MKDIR = mkdir
RM = /bin/rm -f
TOUCH = touch
ARCH = Linux_PII_CBLAS
TOPdir = $(HOME)/bench/hpl
INCdir = $(TOPdir)/include
BINdir = $(TOPdir)/bin/$(ARCH)
LIBdir = $(TOPdir)/lib/$(ARCH)
HPLlib = $(LIBdir)/libhpl.a
MPdir = /opt/openmpi/intel/
MPinc = -I$(MPdir)/include
MPlib = -L $(MPdir)/lib/ -lmpi
LAdir = /opt/intel/Compiler/11.1/064/mkl/lib/em64t/
LAinc = -I /opt/intel/Compiler/11.1/064/mkl/include/
LAlib = $(LAdir)/libmkl_scalapack_ilp64.a $(LAdir)/libmkl_solver_ilp64.a -Wl,--start-group $(LAdir)/libmkl_intel_ilp64.a $(LAdir)/ ibmkl_intel_thread.a $(LAdir)/libmkl_core.a $(LAdir)/libmkl_blacs_openmpi_ilp64.a -Wl,--end-group -openmp -lpthread
F2CDEFS =
HPL_INCLUDES = -I$(INCdir) -I$(INCdir)/$(ARCH) $(LAinc) $(MPinc)
HPL_LIBS = $(HPLlib) $(LAlib) $(MPlib)
HPL_OPTS = -DHPL_CALL_CBLAS
HPL_DEFS = $(F2CDEFS) $(HPL_OPTS) $(HPL_INCLUDES)
CC = mpicc
CCNOOPT = $(HPL_DEFS)
CCFLAGS = $(HPL_DEFS)
LINKER = mpicc
LINKFLAGS = $(CCFLAGS)
ARCHIVER = ar
ARFLAGS = r
RANLIB = echo
Compilation is OK. But when I run HPL I get:
[umt1:09761] *** Process received signal ***
[umt1:09761] Signal: Segmentation fault (11)
[umt1:09761] Signal code: (-6)
[umt1:09761] Failing at address: 0x2c4200002621
[umt1:09761] [ 0] /lib64/libpthread.so.0 [0x359200e4c0]
[umt1:09761] [ 1] /lib64/libpthread.so.0(raise+0x2d) [0x359200e38d]
[umt1:09761] [ 2] /opt/intel/Compiler/11.1/064/lib/intel64/libiomp5.so [0x2b613a32a4a2]
[umt1:09761] *** End of error message ***
mpirun noticed that process rank 0 with PID 9761 on node umt1 exited on signal 11 (Segmentation fault).
If recompile HPL with ATLAS - I have no problem with compilation and running.
TimP
Questions about MKL will get expert attention sooner on the MKL forum.
2 questions:
Are you using 64-bit integer arguments consistently for the ilp64 link option?
Did you check whether you have set a sufficient stack limit?
i1ya
About first question: Where I can see it ?
About second: I think so, here is my ulimit output:
[u1330@umt100 ~]$ ulimit -a
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 135167
max locked memory (kbytes, -l) unlimited
max memory size (kbytes, -m) unlimited
open files (-n) 10000
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) 10240
cpu time (seconds, -t) unlimited
max user processes (-u) 135167
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited
TimP
Quoting i1ya
This looks quite small.
http://software.intel.com/en-us/forums/intel-math-kernel-library/
