HTMulticore library
bipsen
Hi
On my quest for locating info on how to get CPU information on Windows, I found the HTMulticore library on http://software.intel.com/en-us/articles/hyper-threading-technology-multi-core-and-mobile-intel-pentium-processor-m-toolbox/
The problem is, that I'm unable to use the linker library in my own code, since it aparently wants to use LIBC.lib as well - and this library doesn't exist with Visual Studio 2008.
Doesn anyone have an idea to solve this - or is it possible to have the author recompile the library code, so it can be used with Visual Studio 2008 ?
bipsen
TimP
This certainly makes the library look out of date, probably not intended for current platforms. How could a multicore library be linked against the non-threadsafe library? You should be able to set /nodefaultlib:libc.lib in order to persuade it to accept the libcm.... version from VS2008.
mahmoudgalal1985
Quoting - tim18
Thank you
bipsen
Another problem has popped up....
I can only get the HTMulticore library to work with Win32 code... If I try to make an x64 executable, it seems like the library cannot be used.
I need to create 2 versions of my application, since I'm using another external API - and that API will not exist in both 32 and 64 bit on a 64-bit OS by default....
/B
TimP
As the library appears to be intended for VS2003, which doesn't support X64, such a limitation is to be expected.
ninhngt
Quoting - bipsen
/B
It seems this is a very old library. You should consider using Intel TBB and sign up for Ct, too.
