Haswell TSX using RTM (beginner student)
tshan_k_
I am just getting introduced into haswell's TSX infrastructure using RTM. I have downloaded the rtm.h header files from online and i tried producing a simple counter. Unfortunately every time i compile and run the program, the _xbegin function does not execute the transaction inside.  I would be greatly appreciated for your help. thanks
#include <stdio.h>
#include <stdlib.h>
#include "rtm.h"
void main(){
    int N=5;
    int i;
    int status;
    int counter = 0;
    status = _xbegin();
if (status == _XBEGIN_STARTED)
    for (i=0; i<N ; i++)  {
        counter++;
        printf("counter value: %d\n", counter);
    _xend();
else
    printf("did not work\n");
le_g_1
You should not use print inside a transactional region. I/O is  unfriendly instruction. When the transaction is aborted,  the program goes to the else statement.
le_g_1
jimdempseyatthecove
FWIW placing a break point inside a transactional region will abort the transaction. Debug your code as a critical section, then convert to TSX or RTM.
Jim Dempsey
tshan_k_
thank you le g. and jimdempseyatthecove when i put the printf function after the _xend the transaction works. thanks again for your quick help
