1707 Discussions
Haswell Transactional Memory read/write-set information
YangHun_P_
Recently, Intel release haswell machines which support hardware transactional memory called transactional synchronization extension(TSX).
As Intel manual said, Speculative memory operations, write-set and read-set, are buffered in L1 cache and L2 cache each. (not exactly)
Then, Can I track transactional memory operations and get information like address, and values of read/write-set?
gaston-hillar
Valued Contributor I
Hi YangHun,
Intel® VTune™ Amplifier XE 2015 Update 2 added Intel® Transactional Synchronization Extensions (Intel® TSX) TSX Hotspots analysis. It provides clockticks data for Haswell microarchitecture. You can read more details about it here.
Hope it helps.
