How to manipulate a "thread-scoped" MSR?
sm_w_
I am trying to understand how Machine Check Architecture (MCA) works. It consists of a set of global configuration/status MSRs and several bank of MSRs for error logging.
In Intel Manual Vol.3 Ch.35, I see some MCA global MSRs are "thread-scoped", such as:
IA32_MCG_STATUS (0x17AH) in Xeon Phi processor.
The manual says in Vol.3. Ch.35.6:
“Thread” means this bit field must be programmed on each logical processor independently.
So, if I want to manipulate some bits of a thread-scoped MSR, I have to make sure that the code containing the manipulation logic is executed on the logical processor which owns that thread-scoped MSR
And although the thread-scoped MSR has only one fixed address (e.g. 0x17AH for IA32_MCG_STATUS), visit this same address on different logical processor will visit different MSRs.
Is my understanding right?
If so, how can I designate which logical processor to run my code?  For example, I want to write to a thread-scoped MCA MSR so that I can inject/spoof some hardware error to validate the whole error handling stack.
McCalpinJohn
The details will depend on your OS and whether you are running in the kernel or in user space....
If you are running on a Linux system, running in user space, you can use the /dev/cpu//msr device driver interface to handle the core mapping for you.  E.g., if you want to read an MSR on logical processor 3, you open /dev/cpu/3/msr and perform a "pread()" operation using the MSR number as the "offset" parameter.    I recommend downloading the msr-tools 1.3 package from https://01.org/msr-tools and seeing how the "rdmsr.c" and "wrmsr.c" command-line utilities perform these simple operations.
If you are on a Linux system and running in kernel space (e.g., inside a device driver), there are helper routines defined to execute the RDMSR instruction on a target logical processor.  In the 3.10 kernels that I use the interfaces are "rdmsr_safe_on_cpu()" and "wrmsr_safe_on_cpu()".  These interfaces set up the inter-processor interrupts necessary to start up a kernel process on the target core and have it read the MSR on that core, then return the value to the calling process.
