Hyperthreading problem
abirch
I have 2 pc's configured this way:
2.8GHz(w/hyper-threading)
ASUS MB P4P8X SE
256MB PC3200
and
2.4GHzC(w/hyper-threading)
ASUS MB P4P8X
512MB PC3200
Problem: 2.8GHz shows HT enabled in the BIOS and can run 2 separate threads just as you would on a multi-processor pc. The 2.4GHz shows HT enabled in the BIOS but I am unable to run separate threads as I do on the 2.8GHz. When I do the applications compete for cpu time. The MB have the identical BIOS versions installed. The MB, processors and memory all support hyper-threading technology. Am I missing something?
Thanks for your replies
Allan
Henry_G_Intel
Hi Allan,
What operating system are you using? If you're using Windows, does the Task Manager show two CPU's? If Linux, does top show two CPU's?
Henry
