I think I'm just missing the right linker setting
davehiatt
Can someone familiar with the MIC boxdirectory setuptake a quick look at this ICC compile command line. I believeall that is probably wrong is I'm leaving out alib reference but I'm having a brain malfunction. I just basically modified my gcc build and BTW the gcc build works fine, hence my suspicion that it's a missing reference that will be obvious to someone more familiar with the KNF box set up. Thanks
Here's the error I'm getting
GCC builds fine, we have an issue during linking with intel:
We are using -L/opt/intel/composerxe_mic//compiler/lib/mic to for the Intel libraries.
/emap/mpich2-1.4.1p1-64//bin/mpicxx -cxx=/opt/intel/composerxe_mic//bin/mic/icpc -offload-build -ipo -openmp -opt-report-phase=offload -O3 -static -L/emap/mpich2-1.4.1p1-64//lib -L/home/citi/workspace/emap-2.0/src/DKora/../../lib/espiel546 -L/opt/intel/composerxe_mic//compiler/lib/mic -offload-build -L/emap/mpich2-1.4.1p1-64//lib -L/home/citi/workspace/emap-2.0/src/DKora/../../lib/espiel546 DKora.o -o DKora546 /home/citi/workspace/emap-2.0/src/DKora/../CMIFinancialLib/libCMIFinancialLib.a -lespmodel -lprepayScore -lmpich -lmpichcxx
ipo: warning #11021: *MIC* unresolved MPI_Bcast
Referenced in /tmp/ipo_icpcRxOSMV.o
ipo: warning #11021: *MIC* unresolved MPI_Send
ipo: warning #11021: *MIC* unresolved MPI_Comm_size
ipo: warning #11021: *MIC* unresolved MPI_Recv
ipo: warning #11021: *MIC* unresolved MPI_Comm_rank
ipo: warning #11021: *MIC* unresolved _ZN3MPI23MPIR_Call_world_errhandEi
ipo: warning #11021: *MIC* unresolved MPI_Get_count
ipo: warning #11021: *MIC* unresolved _ZN18CRefiTurnoverModelD1Ev
ipo: warning #11021: *MIC* unresolved _ZN21CStateModelParametersD1Ev
ipo: warning #11021: *MIC* unresolved _ZN24CRemittanceScheduleRulesD1Ev
ipo: warning #11021: *MIC* unresolved _ZN5CSwapD1Ev
ipo: warning #11021: *MIC* unresolved _ZN5CEuroD1Ev
ipo: warning #11021: *MIC* unresolved _ZN24CInitialShortRateFactory14CreateInstanceER17CRunConfigurationi
ipo: warning #11021: *MIC* unresolved _ZN5CSwap5ValueEil12CCMISmartPtrI17CDiscountFunctionE
ipo: warning #11021: *MIC* unresolved _ZN9CMortgage18InitializeMortgageEi12CCMISmartPtrI7CLedgerE
ipo: warning #11021: *MIC* unresolved _ZN9CMortgage5ValueEili
ipo: warning #11021: *MIC* unresolved _ZN12CPassThrough3NewERSs
ipo: warning #11021: *MIC* unresolved _ZN9CMortgage3NewERSs
ipo: warning #11021: *MIC* unresolved _ZN9CMortgage13SetNextLedgerE12CCMISmartPtrI7CLedgerE
ipo: warning #11021: *MIC* unresolved _ZN9CMortgage20SetAsPassThroughLoanEd
ipo: warning #11021: *MIC* unresolved _ZN12CPassThroughC1ERKSsR17CRunConfiguration12CCMISmartPtrI7CLedgerE
ipo: warning #11021: *MIC* unresolved _ZN12CPassThroughC1ER17CRunConfiguration12CCMISmartPtrI7CLedgerE
ipo: warning #11021: *MIC* unresolved _ZN9CMortgageC1ER17CRunConfiguration12CCMISmartPtrI7CLedgerE
ipo: warning #11021: *MIC* unresolved _ZN9CMortgageC1ERKSsR17CRunConfiguration
ipo: warning #11021: *MIC* unresolved _ZN14CPaymentStatus4copyERS_
ipo: warning #11021: *MIC* unresolved _ZN20CUnemploymentProcessD1Ev
ipo: warning #11021: *MIC* unresolved _ZN11CHPIProcessD1Ev
ipo: warning #11021: *MIC* unresolved _ZN17CLiborMarketModelD1Ev
ipo: warning #11021: *MIC* unresolved _ZN15CScenarioEngine15createScenariosER17CLiborMarketModelR20CUnemploymentProcessR11CHPIProcess12CCMISmartPtrI17CDiscountFunctionES8_
ipo: warning #11021: *MIC* unresolved _ZN17CLiborMarketModel22CalibrateNonParametricEv
ipo: warning #11021: *MIC* unresolved _ZN17CLiborMarketModel9CalibrateEid
ipo: warning #11021: *MIC* unresolved _ZN17CLiborMarketModelC1E12CCMISmartPtrI17CDiscountFunctionER17CRunConfigurationR18CPathRandomNumbers
ipo: warning #11021: *MIC* unresolved _ZN11CHPIProcessC1ER17CRunConfiguration
ipo: warning #11021: *MIC* unresolved _ZN20CUnemploymentProcessC1ER17CRunConfiguration
ipo: warning #11021: *MIC* unresolved _ZN15CScenarioEngine16setStepIntervalsEl
ipo: warning #11021: *MIC* unresolved _ZN17CRunConfiguration10GetModDateEi
ipo: warning #11021: *MIC* unresolved _ZN17CRunConfiguration25initializeLedgerItemCodesEv
ipo: warning #11021: *MIC* unresolved _ZN21CStateModelParametersC1ER4CDal
ipo: warning #11021: *MIC* unresolved _ZN24CRemittanceScheduleRulesC1Ev
ipo: warning #11021: *MIC* unresolved _ZN13CScenarioType17parseGenericShockESs
ipo: warning #11021: *MIC* unresolved _ZN13CScenarioType13parseVolShockEd
ipo: warning #11021: *MIC* unresolved _ZN13CScenarioType13parseModShockESs
ipo: warning #11021: *MIC* unresolved _ZN13CScenarioType22parseInterestRateShockEv
ipo: warning #11021: *MIC* unresolved _ZN5CSwapD2Ev
ipo: warning #11021: *MIC* unresolved _ZN5CSwap10initializeEv
ipo: warning #11021: *MIC* unresolved _ZN3MPI8FinalizeEv
ipo: warning #11021: *MIC* unresolved _ZN3MPI4InitEv
ipo: warning #11021: *MIC* unresolved _ZN3MPI18Get_processor_nameEPcRi
ipo: warning #11021: *MIC* unresolved _ZN3MPI10COMM_WORLDE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIidSt3mapIidSt4lessIiESaISt4pairIKidEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl16CSchedAmortEntrySt3mapIlS0_St4lessIlESaISt4pairIKlS0_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISs12CCMISmartPtrIS_ISsS0_IS_IiS0_I6CCurveESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EEES3_ISsSD_S4_ISsESaIS6_IKSsSD_EEELSB_1EEES3_ISsSK_SE_SaIS6_ISF_SK_EEELSB_1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI16CPassThroughRuleESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISsdSt3mapISsdSt4lessISsESaISt4pairIKSsdEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi11CThreadDataSt3mapIiS0_St4lessIiESaISt4pairIKiS0_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI11CShockPointESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI18CPathRandomNumbersESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIySt4pairImyESt3mapIyS1_St4lessIyESaIS0_IKyS1_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrIS_IiSsSt3mapIiSsSt4lessIiESaISt4pairIKiSsEEEL9OPERATION1EEES1_IiSB_S3_SaIS4_IS5_SB_EEELS9_1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIiSt17_Rb_tree_iteratorISt4pairIKiSsEESt3mapIiS4_St4lessIiESaIS1_IS2_S4_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrISt8multimapIiSsSt4lessIiESaISt4pairIKiSsEEEESt3mapIiS9_S3_SaIS4_IS5_S9_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIiSt4pairIilESt3mapIiS1_St4lessIiESaIS0_IKiS1_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV12CPassThrough
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISsSsSt3mapISsSsSt4lessISsESaISt4pairIKSsSsEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI6CCurveESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISs12CCMISmartPtrIS_IiS0_I6CCurveESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EEES3_ISsSD_S4_ISsESaIS6_IKSsSD_EEELSB_1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIiiSt3mapIiiSt4lessIiESaISt4pairIKiiEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI7CLedgerESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrIS_IiiSt3mapIiiSt4lessIiESaISt4pairIKiiEEEL9OPERATION1EEES1_IiSB_S3_SaIS4_IS5_SB_EEELS9_1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrIS_IiS0_I7CLedgerESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EEES3_IiSD_S5_SaIS6_IS7_SD_EEELSB_1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISs12CCMISmartPtrI6CCurveESt3mapISsS2_St4lessISsESaISt4pairIKSsS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI16CPortfolioLedgerESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV16CPortfolioLedger
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISs12CCMISmartPtrI7CLedgerESt3mapISsS2_St4lessISsESaISt4pairIKSsS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV7CLedger
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI11CLedgerItemESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIllSt3mapIllSt4lessIlESaISt4pairIKllEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CLedgerItem
ipo: warning #11021: *MIC* unresolved _ZTV17CRunConfiguration
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISs12CCMISmartPtrI14CStrategyEntryESt3mapISsS2_St4lessISsESaISt4pairIKSsS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISsiSt3mapISsiSt4lessISsESaISt4pairIKSsiEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl12CCMISmartPtrI17CUnemploymentPathESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl12CCMISmartPtrI9CRatePathESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl12CCMISmartPtrI8CHPIPathESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrIS_IlS0_I17CUnemploymentPathESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EEES3_IiSD_S4_IiESaIS6_IKiSD_EEELSB_1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrIS_IlS0_I9CRatePathESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EEES3_IiSD_S4_IiESaIS6_IKiSD_EEELSB_1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrIS_IlS0_I8CHPIPathESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EEES3_IiSD_S4_IiESaIS6_IKiSD_EEELSB_1EE
ipo: warning #11021: *MIC* unresolved _ZTV9CRatePath
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl12CCMISmartPtrI13CForwardRatesESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV13CForwardRates
ipo: warning #11021: *MIC* unresolved _ZTV8CHPIPath
ipo: warning #11021: *MIC* unresolved _ZTV17CUnemploymentPath
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISs12CCMISmartPtrI9CScenarioESt3mapISsS2_St4lessISsESaISt4pairIKSsS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV14CStrategyEntry
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionISs12CCMISmartPtrI13CStrategyInstESt3mapISsS2_St4lessISsESaISt4pairIKSsS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV9CScenario
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIi12CCMISmartPtrI13CScenarioTypeESt3mapIiS2_St4lessIiESaISt4pairIKiS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV13CScenarioType
ipo: warning #11021: *MIC* unresolved _ZTV10CBasisPath
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl12CCMISmartPtrI6CCurveESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV17CHistoricRateList
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl12CCMISmartPtrI18CHistoricRateEntryESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CMarketData
ipo: warning #11021: *MIC* unresolved _ZTV17CDiscountFunction
ipo: warning #11021: *MIC* unresolved _ZTV6CCurve
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIldSt3mapIldSt4lessIlESaISt4pairIKldEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIiSsSt3mapIiSsSt4lessIiESaISt4pairIKiSsEEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTV18CPathRandomNumbers
ipo: warning #11021: *MIC* unresolved _ZTV11CCollectionIl12CCMISmartPtrI17CStepIntervalDataESt3mapIlS2_St4lessIlESaISt4pairIKlS2_EEEL9OPERATION1EE
ipo: warning #11021: *MIC* unresolved _ZTI15CCmippException
ipo: warning #11021: *MIC* unresolved _ZTVN3MPI6StatusE
ipo: warning #11021: *MIC* unresolved _ZTVN3MPI8DatatypeE
ipo: warning #11021: *MIC* unresolved _ZTV15CCmippException
ipo: remark #11001: *MIC* performing single-file optimizations
ipo: remark #11006: *MIC* generating object file /tmp/ipo_icpcRxOSMV.o
ipo: warning #11003: no IR in object file /tmp/icpcesQxOF.o; was the source file compiled with -ipo
ipo: warning #11060: /home/citi/workspace/emap-2.0/src/DKora/../CMIFinancialLib/libCMIFinancialLib.a is an archive, but has no symbols (this can happen if ar is used where xiar is needed)
ipo: warning #11010: file format not recognized for /home/citi/workspace/emap-2.0/src/DKora/../CMIFinancialLib/libCMIFinancialLib.a
ipo: warning #11010: file format not recognized for /tmp/icpcesQxOF.o
ipo: warning #11021: unresolved MPI_Bcast
Referenced in /tmp/ipo_icpc81Ir0k.o
Link errors:
x86_64-l1om-linux-ld: skipping incompatible /home/citi/workspace/emap-2.0/src/DKora/../../lib/espiel546/libespmodel.a when searching for -lespmodel
x86_64-l1om-linux-ld: cannot find -lespmodel
x86_64-l1om-linux-ld: skipping incompatible /home/citi/workspace/emap-2.0/src/DKora/../../lib/espiel546/libprepayScore.a when searching for -lprepayScore
x86_64-l1om-linux-ld: cannot find -lprepayScore
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64//lib/libmpich.a when searching for -lmpich
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64/lib/libmpich.a when searching for -lmpich
x86_64-l1om-linux-ld: cannot find -lmpich
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64//lib/libmpichcxx.a when searching for -lmpichcxx
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64/lib/libmpichcxx.a when searching for -lmpichcxx
x86_64-l1om-linux-ld: cannot find -lmpichcxx
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64//lib/libopa.a when searching for -lopa
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64/lib/libopa.a when searching for -lopa
x86_64-l1om-linux-ld: cannot find -lopa
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64//lib/libmpl.a when searching for -lmpl
x86_64-l1om-linux-ld: skipping incompatible /emap/mpich2-1.4.1p1-64/lib/libmpl.a when searching for -lmpl
x86_64-l1om-linux-ld: cannot find -lmpl
x86_64-l1om-linux-ld: cannot find -liomp5
TimP
The identical question has been posted without clorification on the forum pertaining to this platform.
